Effector under angle. Plz help!!!
uploading
@goretec can you please also post your config.g?
@goretec is it only in the Y direction? Are you running 3.3 or one of the 3.4 betas?
As well as your config, what motors are you using? and which duet board? -
Duet wifi 3.4.0 beta3
surestep 17048 steppers (2amp)
; generated by RepRapFirmware Configuration Tool v3.2.3 on Thu Jun 17 2021 20:58:10 GMT+0200 (Midden-Europese zomertijd)
G21 ;work in millimeters
M550 P"DeltaPro" ; set printer name
M665 R120 L288.13 B110 H312 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
M551 P"goretec" ; set password
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M586 P2 S0 ; disable Telnet
M569 P3 S1 ; physical drive 3 goes backwards
M92 X80.00 Y80.00 Z80.00 E420.00 ; set steps per mm
M566 X3500.00 Y3500.00 Z3500.00 E3000.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E18000.00 ; set maximum speeds (mm/min)
M201 X3000.00 Y3000.00 Z3000.00 E600.00 ; set accelerations (mm/s^2)
M906 X1500 Y1500 Z1500 E1200 I15 ; set motor currents (mA) and motor idle factor in per cent
M84 S15 ; Set idle timeout
M208 Z0 S1 ; set minimum Z
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
M558 P5 R0.25 C"zprobe.in+zprobe.mod" H5 F600 T2500 ; set Z probe type to effector and the dive height + speeds
G31 P50 X0 Y0 Z-0.148 ; set Z probe trigger value, offset and trigger height
M557 R110 S20 ; define mesh grid
M308 S0 P"bedtemp" Y"thermistor" T100000 B4900 C0 R4700 ; configure sensor 0 as thermistor on pin bedtemp
M143 H0 S125 ; set temperature limit for heater 0 to 125C
M308 S1 P"e0temp" Y"thermistor" T100000 B4725 c7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
M106 P0 C"Layer Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"Hotend Fan" S1 H1 T50 ; set fan 1 name and value. Thermostatic control is turned on
M563 P0 S"Hotend" D0 H1 F0 ; define tool 0
M911 S20 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss -
@goretec can you try the same print using 3.3.0?
shall try when im home
i get big endstop corrections.
M666 X1.974 Y-0.770 Z-1.204 A-1.27 B-0.09
i mounted them with calibers they shouldnt be so far off
@goretec thats not the worst i've seen so I wouldn't worry.
I'm more interested in seeing how it comes out with 3.3 -
@jay_s_uk When im home in 5 hours i shall test it.
@goretec said in Effector under angle. Plz help!!!:
Tested it with firmware 3.30 stable.
Sadly problem still exists
@goretec what's in your bed.g file?
