Question about Object models
Good morning,
Is there an object model to know the direction of rotation of the motor?
When you send M569 Pn it does indicate it, but I can't find the corresponding object model.
M569 P2
Drive 2 runs forwards, active low enable, timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknownM569 P1
Drive 1 runs in reverse, active low enable, timing fast, mode spreadCycle, ccr 0x101b4, toff 4, tblank 2, hstart/hend/hdec 3/3/0, pos unknownBest regards
@aitor this is not yet in the OM, we plan to add it and a few other things that are set by gcodes but not readable via the OM. I can't yet give a timeline for when they will be added.
Good morning @t3p3tony,
I'm still lost with some OM expressions I guess you are referring to object models
When you say it is not added, do you mean that it is not in the DWC plugin or that this object model does not exist?
I want to use it to generate a config.g from >>echo commands that were implemented in beta 3.4, and this is the only variable that I have left in my case to finish, and it is one that usually changes from one machine to another.
Best regards
@aitor I mean that it is not yet in the object model so there is no way to reference it with the echo or other commands that use the OM. At this this point all you can do is send the M569 Pn command to see the current setting.
A pity, I hope they can add it soon
I'll have to do it manually for now
Thanks for the quick reply
Best regards
