DWC: Button Step Adjustment is not Saved after Restart?
@jay_s_uk do you know/ or do someone know how that could be changed? for example i have a
Z Axis with 50, 25, 1, 0,1 and a U Axis with 100, 50, 5, 0,5
that Values are also saved somewhere? -
@neueklasse oh, those ones
they should get written automatically to dwc-settings.json in the system folder -
What DWC version are you using?
@phaedrux the Last Update, 3.4.0
@jay_s_uk i tried to adjust these Settings (dwc-settings.json, dwc2-settings.json)
after Restart nothing changed, but the Adjustments i took in that 2 files are still ok...
i'm confused a little bit... -
@neueklasse you could just delete them and let DWC recreate them and see if that sorts it out
@jay_s_uk after Deleting these 2 Files, Configuring the "new Step Values"
and Restarting the Board, everything is the same... the Step Values doesn't Change.Interesting is:
- in DWC the U and W Values are 50, 25, 1, 0,1 (sorry the Post from 6.9.21 (19:26) was wrong.
(Z Axis Starts at 25...)) - and on the Paneldue the U and W Values start at 100.. (that's the default value in the json files)
@neueklasse maybe @chrishamm can comment
@neueklasse said in DWC: Button Step Adjustment is not Saved after Restart?:
beta3? SBC mode or standalone?
@phaedrux standalone mode, beta3, correct.
