Fans doesn't work anymore
Good morning, I was changing the cooling fan of my duet 2 WiFi...I don't know what is happen but non NO fan works...the PWM or the always on as well...ALL DEAD....what could be happened? Have I burned up the board? All other functions seems to work....could someone help me please?
Depending on the hard version you may have just blown a fuse. The 1.04 has one for the fans and other things if I remember correctly
@jay_s_uk said in Fans doesn't work anymore:
I confirm....I burned the fuse.....thanks
it's a 1A fuse, right?
@the_dragonlord said in Fans doesn't work anymore:
Yes. You can replace it by a 2A fuse if the total load on the fan outputs exceeds 1A.
@dc42 said in Fans doesn't work anymore:
Thanks!
