SAM4E16E build configuration
Hi,i want to replace SAM4E8E with SAM4E16E. I don’t know if there are any other differences than the amount of flash. The CoreNG only has build configuration with SAM4E8E, could this configuration work for SAM4E16E?
@leoyu AFAICS they are mostly identical except for the adress of CHIPID_EXID register. It might suffice to replace
__SAM4E8E__
with__SAM4E16E__
in the CoreN2G project settings and to recompile the firmware then. Also, you'd have to use a different linker script if you wanted to use the full flash memory. -
@chrishamm Thank you, this is good info
@chrishamm hi chrishamm, when compile SAM4E16E , i get the question with link script, hope to get your help.
1.which folder is the linker script file located,how can i find the linker script for SAM4E16E2.if I get the linker script, may I just modify some parameters in linker script of SAM4E8E to match SAM4E16E, when I attempt to use the same coreng to be compatible with SAM4E8E and SAM4E16E in different project
3 .what if i write the BIN file built under SAM4E8E project into SAM4E16E chip
Many thanks -
@leoyu said in SAM4E16E build configuration:
1.which folder is the linker script file located,how can i find the linker script for SAM4E16EIt's in src/Hardware/SAM4E in the RRF project
Yes. I think the only change you need to make for the SAM4E16 is to change the LENGTH field of the rom section from 0x80000 to 0x100000.
Yes that should work.
@dc42 thanks so much
@leoyu Hey, did you get any answers? I would be interested as well
@leoyu Hello.
I was interested in this SAM4E16E retrofit, too, for a Duet2 board in order to boost flash size. Seems like the pinouts are same.
Did you have any luck with this? Any firmware files for this?
