Configtool cert expired
I think that you guys want to ask letsencrypt for a new cert for the config tool:
Cheers, Chriss
That must be an alternate URL. Will look into it, thanks.
https://configtool.reprapfirmware.org/Start Is still valid.
Oh, you may be right... I'm not sure where I got that hostname from. Maybe google, maybe my browser history.
Cheers, Chriss
@chriss Thanks, I've found the old link on 8 pages in the wiki; I'll update them.
Cool... I found the source of the confusion, too. I have a bookmark for it. So FF shows me the bookmark when I start typing "configtool"... So we both have a "bug"here.
May I ask which the correct URL is?
I found https://configtool.reprapfirmware.org/Start on https://duet3d.dozuki.com/Wiki/SD_Card
Which is wrong, isn't it?
Cheers, Chriss
@chriss https://configtool.reprapfirmware.org/Start is the correct address, configurator... is the old one. It forwards to configtool, but it still needs an up-to-date certificate if you land on the configurator... page, even if it's just forwarding to configtool. If you got to https://www.reprapfirmware.org/ and click on config tool, you'll see it goes to https://configtool.reprapfirmware.org/
Checking with an SSL certificate checker, configurator... has lapsed, but configtool... is still valid. Are you still getting a certificate warning?
@droftarts said in Configtool cert expired:
Thanks for the clarification. I simply lost a bit track about all of that. Clear now... "configurator" - "configtool" are just to similar words for my filter.
Not on the configtool.
But there is a problem with the redirect at:
https://configurator.reprapfirmware.orgThere is a "/" missing.
You will get redirected to:
https://configtool.reprapfirmware.orgStart/
When you try to reach:
https://configurator.reprapfirmware.org/StartI guess that you miss a "/" in front of the "$1" in the RewriteRule.
Cheers, Chriss
@chriss the redirect works for me on chrome.
just the certificate thats expired -
It has nothing to do with the browser the apache is misbehaving:
curl -k https://configurator.reprapfirmware.org/Start <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>301 Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The document has moved <a href="https://configtool.reprapfirmware.orgStart">here</a>.</p> <hr> <address>Apache/2.4.38 (Debian) Server at configurator.reprapfirmware.org Port 443</address> </body></html>
Line one shows that I try to reach "/Start", line 7 shows that the redirect points to "...orgStart". So the "/" is gone.
You need a "/" before "$1" in the apache config.
And you may want to set:
ServerTokens Prod
You may not want to tell everybody your Apache version and the OS where it is hosted on.
Cheers, Chriss
@chriss It's only a problem if your saved link is
; the 'Start' is put in automatically on the configtool page, and I guess it was when the address was configurator, so that's what was saved when you bookmarked the link. If you use the configurator link without Start (with or without trailing /), it works fine. I don't think it's linked anywhere in the wiki with the 'Start' on the end, so it's only a bookmark issue. I'll see if the redirect can be updated.Ian
;Will all respect, I do not agree.
Your redirect rule misbehaves, here is no Bookmark or whatever involved:
(look t line 1 and 7)[chriss@leela ~]$ curl -k https://configurator.reprapfirmware.org/BlueSmurf42 <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN"> <html><head> <title>301 Moved Permanently</title> </head><body> <h1>Moved Permanently</h1> <p>The document has moved <a href="https://configtool.reprapfirmware.orgBlueSmurf42">here</a>.</p> <hr> <address>Apache/2.4.38 (Debian) Server at configurator.reprapfirmware.org Port 443</address> </body></html> [chriss@leela ~]$
I understand that you do not need the /Start any more on the old hostname an you do have a link to /Start any more. But you should redirect correctly when you redirect the uri and not the hostname only.
But this is not my problem at the end...
Cheers, Chriss
Thanks, both the expired certificate and the redirect are now fixed. For the latter it may be necessary to wait a few days or to clear the browser cache once.
