[RRF 3.3] Parsing Error
Even after upgrading to RRF 3.3 , I get Parsing Error.
Board : Duet 3 MB6HC
RRF : 3.3
Also what does "slowing down poll rate" indicate?P.S:Monitoring everything on DWC at the same time.
@user3d please run M115 to check that you really are running 3.3 stable.
@dc42 yup
25/06/2021, 10:27:18 M115 FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.3 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2021-06-22 17:22:04
P.S. : I have my own changes applied on RRF(branch: 3.3-dev) .
@user3d said in [RRF 3.3] Parsing Error:
I suspect you are not using the 3.3 release CoreN2G files. They were changed shortly before the release to fix this issue.
@dc42 To build RRF ,I confirm that I've used 3.3 release of all the
projects including CoreN2G as instructed in https://github.com/Duet3D/RepRapFirmware/wiki/Building-RepRapFirmware . Downloaded all on the same date i.e. 2021-06-22 . -
@user3d in that case I think the PanelDue cable must be picking up interference.
That message has been downgraded to a warning in the latest PanelDue firmware.
@user3d try shielded wires?
