Homex - and I am getting fed up
Fingernails won't nick your wire!
I can't help but wonder what @Reefwarrior uses to crimp the connectors ..... -
@Phaedrux said in Homex - and I am getting fed up:
stripped some wire with his fingernails.
silicone wire and some wirewrap wire (and probably other types) strips relatively easily with just fingernails - no big deal tbh
@gaweyo said in Homex - and I am getting fed up:
no big deal tbh
I thought it badass to be honest. -
@Reefwarrior said in Homex - and I am getting fed up:
To be honest, I was expecting a pair of pliers
If the jaws are machined then you are golden, if they are cast then you still have a problem. -
They look identical to what I use. For what it's worth I found that I had to do a slightly lighter than full squeeze on some cables to prevent it from pinching the wire. I've since upgraded to a nicer pair with interchangeable jaws that are much better formed and it works perfectly everytime.
@Phaedrux Yeah waiting for my new one to arrive
@jens55 Yep machined - not cast.
@Reefwarrior
Copper quality can also vary and the cheaper ones can break easier than others.
For the record, I use a formerly sharp knife to cut the insulation or (*) sometimes my teeth
And I'm a big fan of soldering (after crimping with pliers or instead of)*) don't try this at home kids
@o_lampe It is my professional opinion as a dentist that using your teeth to strip wires is a bad idea. This is a better option, and much cheaper than a single trip to the dentist to repair a chipped tooth: https://www.homedepot.com/p/KNIPEX-7-in-Automatic-Wire-Stripper-12-62-180/205333645
@mrehorstdmd
I agree, but after opening a few beer with teeth they can stand it
Just kidding, I don't drink beer.
