RRF 3.1.1 with DWC 3.2?
Hi guys, I have a duet 2 wifi with 3.1.1 firmware and I use Duet Web Control 3.1.1 and I would like to know if I can install DWC 3.2 without updating the firmware to 3.2 or if I need to update both.
Thank you -
you can use 3.2.2 DWC with 3.1.1
Why would you not want to update? -
Just update to firmware 3.2.2 - it works fine.
At this point it's probably best to stay in step between firmware and DWC versions especially as DWC begins to use the object model more which may depend on the firmware.
They are released together now, so best to update both.
I had read about some problems on RRF 3.2.2. As soon as I have a moment I update both of them and hopefully well.
Thanks everyone for the answers.
