Motors working then chatter before and after homing...
M122
M122
RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2.2 running on Duet WiFi 1.02 or later
Board ID: 08DGM-917NK-F2MS4-7JKD6-3SN6K-9GU4G
Used output buffers: 3 of 24 (15 max)
Static ram: 23460
Dynamic ram: 73376 of which 76 recycled
Never used RAM 15168, free system stack 115 words
Tasks: NETWORK(ready,169) HEAT(blocked,200) MAIN(running,449) IDLE(ready,20)
Owned mutexes: WiFi(NETWORK)
Last reset 00:45:14 ago, cause: power up
Last software reset at 2021-03-03 20:03, reason: User, GCodes spinning, available RAM 15168, slot 1
Error status: 0x00
Aux0 errors 0,0,0
MCU temperature: min 22.2, current 29.6, max 30.0
Supply voltage: min 11.6, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0, power good: yes
Driver 0: position 0, standstill, SG min/max 0/319
Driver 1: position 1600, standstill, SG min/max 0/7
Driver 2: position -2000, standstill, SG min/max not available
Driver 3: position 0, standstill, SG min/max 0/320
Driver 5: position 0
Driver 6: position 0
Driver 7: position 0
Driver 8: position 0
Driver 9: position 0
Driver 10: position 0
Driver 11: position 0
Date/time: 2021-03-03 22:39:09
Cache data hit count 3286832726
Slowest loop: 25.80ms; fastest: 0.21ms
=== Storage ===
Free file entries: 10
SD card longest read time 1.6ms, write time 79.8ms, max retries 0
DMs created 83, maxWait 634476ms, bed compensation in use: none, comp offset 0.000
=== MainDDARing ===
Scheduled moves 51, completed moves 51, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 40], CDDA state -1
=== AuxDDARing ===
Segments left: 0
Movement lock held by null
HTTP is idle in state(s) 0
Telnet is idle in state(s) 0
File is idle in state(s) 0
USB is idle in state(s) 0
Aux is idle in state(s) 0
Trigger is idle in state(s) 0
Queue is idle in state(s) 0
LCD is idle in state(s) 0
Daemon is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 186.63ms; fastest: 0.00ms
HTTP sessions: 1 of 8- WiFi -
Network state is active
WiFi firmware version 1.25
WiFi MAC address bc:dd:c2:89:a2:58
WiFi Vcc 3.43, reset reason Power up
WiFi flash size 4194304, free heap 21168
WiFi IP address 192.168.1.7
WiFi signal strength -58dBm, mode 802.11n, reconnections 0, sleep mode modem
Clock register 00002002
- WiFi -
Can you also post your homeall, homex, and config.g as they are right now so we're all looking at the same code?
I notice in the video that when you are jogging it around it's with very short small moves. Have you tried longer distance moves yet?
@Phaedrux said in Motors working then chatter before and after homing...:
M98 P"config.g"
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledError: Temperature reading fault on heater 1: sensor open circuit
home x is the only one im using at the moment.
@wingtip said in Motors working then chatter before and after homing...:
i up'd the current from 1amp (1000mah) to 1.2amp (1200mah) and no change
What is the max rated current for the motors?
unfortunately at the moment i cant due to the huge mess lol... but months ago i was running it the full distance of 800mm no issues
Ill have to check as they came from openbuilds.com but from the config file you gave me they are now down to 800 mah and still chatter before and after homing..
Re-posting of your homeX.g file
; homex.g ; ; generated by RepRapFirmware Configuration Tool v2.1.1 on Sun Nov 03 2019 09:32:23 GMT-0500 (Eastern Standard Time) ; G91 ; relative positioning G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-805 F400 ; move quickly to X axis endstop and stop there (first pass) S1 checks for endstop hit G91 G1 H2 X5 F1800 ; go back a few mm G1 H1 X-10 F360 ; move slowly to X axis endstop once more (second pass) H1 checks for endstop hit G92 X0 G90 G1 H2 Z-5 F2000 ; lower Z again G90 ; absolute positioning
@fcwilt said in Motors working then chatter before and after homing...:
Comment out the Z axis commands, move Z clear with the jog buttons, and try homing again.
I'm curious if longer moves would actually work jogging around because the short back off move in homex does seem to work ok as do the short jogging moves. If the motor current is too low there may be some back emf issues on long moves since the motors have to spin fairly fast due to being lead screw based.
Also, unrelated to the current problem, but will become a problem in the future when you try to use Z. The last Z move you have G90 setting it to absolute positioning and then telling it to go Z-5. Which is not what you want. You want to be using relative moves with G91 so that Z-5 lowers the z axis back down by 5mm.
G90
G1 H2 Z-5 F2000 ; lower Z again -
checked, they are rated to 1.68 amps
Given that the chatter is at the beginning and the end perhaps we are hearing the Z axis?
i can comment them out but cant jog it, as stated z motors arent plugged in right now.
M92 X400.00 Y80.00 Z400.00 E420.00 ; set steps per mm M566 X900.00 Y900.00 Z60.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z20.00 E250.00 ; set accelerations (mm/s^2) M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
I'm assuming you're using the config.g I posted earlier, these values may not be perfect for your setup.
For the motor currents lets set them to 1400ma which is 80% of the rated max and see if it makes any difference.
M92 X400.00 Are we sure your X axis is 400 steps per mm?
Let's reduce the max speed, j**k, and accel for X as well.
Let's try these
M203 X3000
M201 X300
M566 X300
M906 X1400 -
Let's try these
M203 X3000
M201 X300
M566 X300
M906 X1400Will input these right now.....
Well since the chatter occurs at the beginning of the homing and the end but the homing itself works fine the only difference between you jogging X and the homing file is the Z axis commands and they appear at the beginning and end of the homing file.
Thus my suggestion to see if they are the source.
Also, just to eliminate the file, you can send the homing commands manually line by line in the console. The important ones being.
G1 H1 X-805 F400 ; move quickly to X axis endstop -
Ok... I have some good news and some bad news lol..... The good news is you guys are awesome and have saved me from losing my mind.
The bad news is im a stupid idiot.... The chatter is in fact coming from the one z motor that is connected. I had forgotten that one z motor was plugged into the duet board while the 2nd z motor is plugged into the duex expansion board. I only unplugged the ribbon cable of the expansion board to eliminate everything on it, thus forgetting the one z motor on the main board. and im going to guess that i have a crossed wire from the breakout boards to where it finally connects to the board causing the non moving motor.....
i feel like an idiot... as i said in my first video that was the only thing i had changed lol... so i should be able to bump all the speeds and current to the x motors back to where they were if i want... And now fix the z motors and finish the install of the probe.
Makes perfect sense knowing that and watching the homing again.
Glad we could figure it out. And on the plus side, your config is a lot simpler now on RRF3. No more U and V axis and all that non-sense.
We all make foolish mistakes from time to time - no big deal.
Glad to hear it was a simple fix.
