Paneldue says "connecting" and controls nothing
Re: Got my paneldue... It says "connecting" and controls nothing...
@Steve-Lynch did you ever figure out what was going wrong? I have exactly the same issue...
hi @3dpnut what version of the firmware are you running and on what Duet board. if its RRF 3.x you need to explicitly enable the PanelDue port, for example on a
M575 P1 B57600 S1 ;enable panelDue UART
https://duet3d.dozuki.com/Wiki/PanelDue#Section_Firmware_configuration
@T3P3Tony said in Paneldue says "connecting" and controls nothing:
Also, make sure that the paneldue itself is using the same baud rate set in M575. Even when the paneldue isn't communicating with the duet, you can still go into the paneldue's setup page to change that.
Closed due to inactivity. Please re-test with recent version and start a new thread if needed.
