Looking for RRF 3.2 firmware (bin file) for Sammy board
I did look at the GitHub post about compiling your own firmware for the Sammy board (purchased from Fliastruder, with the boot loader pre-installed) but either the links are dead or I am faced with the realization I need to spend several months going blind learning how to use the listed dev tools to do something one of you guys has already done, or can do in 15 minutes.
That said, I believe a good call for help in in order!
I am using RRF 3.2 at the moment but will gladly upgrade to the latest stable (3.2.2?) to be able to experiment with this thing.
In exchange, if you help and forward me an address... I will send you a car Hahaha- Thank You!!!
@beachtec did you see https://duet3d.dozuki.com/Wiki/Using_the_Sammy-C21_development_board_with_Duet_3 ?
Firmware file is in expansion board GitHub repo, but latest seems to be in 3.2b1: https://github.com/Duet3D/Duet3Expansion/releases/tag/3.2beta1
@dc42 does a newer version need to be compiled?
PS what car are you sending me?!
I've added a SAMMYC21 binary to the 3.2.2 release, however I have not tested it.
@beachtec so now it’s here https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2
Still haven’t received my car.
@droftarts Thank you for the help! I am printing it as we speak!
@dc42! Thank you for uploading the Sammy Firmware. It was an easy install and it seems to be working.
BTW, it is not part of the ZIP files in the repository, you have to get it manually. Thank you again for everything you do here!!!
