Endstop wiring and useless documentation:
Yes....
Use logic or go home.
And the logic is even without any documentation the board says "stop" on the top Silk screen. On the bottom silkscreen it says STP, 3v3, GND.
And using Logic again, anyone with half a brain "should" know you do not short vcc to ground..
And you said you didn't have a manual, if that's so how would you know that it doesn't say signal in the manual you don't have?
And the logical thing to do would be to look at the wiring diagram (if available) from looking at it, you can work out how things work.
Without a diagram the logical thing to do would be to test the system with a multi meter
Now I'm all for calling out the duet team for the obvious failings in the documentation (most of the duet team will be only to happy to confirm) but in this case the fact is you are bitching because you failed to do the most basic of research and failed to carry out simple diagnostics
@CaLviNx Don't hold back. Tell us how you really feel.
This exercise in frustration release has been locked.
If there are further questions of a technical nature, or suggestions for improvement of the documentation, please begin a new thread and please remember that an ounce of patience and grace goes a long way.
