PT1000 Source in the UK
My PT1000 has decided it no longer wants to give accurate readings, so time for a replacement, but it seems there's no one currently stocking these in the UK.
My original one came from Precision Piezo, but it's no longer listed on the site or at ooznest or E3D.
Anyone know of a supplier?
Failing that, what is everyone using if not PT1000 currently? -
I've bought from them before and they've been ok
I didn't find any suppliers in the UK, but there is this one in NL: https://reprapworld.co.uk/products/extruder/extruder_parts/temperature_sensors/_pt1000_sensor_with_cartridge/?f=gs. It's 4mm longer than the width of a E3D heater block, so the ends will protrude slightly.
That's fine, I'm using a mosquito hot end which prefers a longer barrel.
Thanks for the info.
PT100 is a much more common sensor.
Although it requires the RTD daughterboard.
