Eventlog not recording
I haven't had my log file log anything for ages. Unsure if it ever logged anything other than "Event logging started".
Using RRF 3.2-beta3.2 (I've made some mechanical changes I want to see work before upgrading to b4.1) on a 6HC+3HC+SBC.M929 P"eventlog.txt" S3
M118 S"Hello Logfile- deb" L3
M118 S"Hello Logfile- info" L2
M118 S"Hello Logfile- warn" L1Nothing logged.
I tried, disabling log, delete and enable logging but still nothing gets logged.
I don't think the event log is supported like that when in SBC mode.
Most things are logged to syslog in /var/log/ -
I did suspect something like that and did doublecheck the documentation and couldn't find anything about that. Would be great to somehow have access to it trough the web interface.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Monitoring_optional
@TypQxQ said in Eventlog not recording:
Agreed.
Maybe add to the documentation of M929 that although it seems to work, it doesn't.
@TypQxQ The intention for 3.2 is to restore M929 functionality.
@Phaedrux I see that should have been fixed in DSF 3.2.0-b1:
"Event logging via M929 was not working"Running 3.2RC2 and it still does not log anything usefull:
2020-12-22 09:18:49 Event logging stopped 2020-12-22 09:19:36 Event logging started 2020-12-22 09:24:20 Event logging stopped 2020-12-23 15:41:13 Event logging started 2020-12-27 16:55:38 Event logging stopped 2020-12-27 16:56:44 Event logging started 2020-12-27 16:57:12 Event logging stopped 2020-12-27 17:00:27 Event logging started
Can you try logging to a file name?
@Phaedrux I have it setup as "M929 P"eventlog.txt" S3" in my config file.
Apparently the S3 does not work and S1 and S2 are switched to what the documentation states.2020-12-28 00:26:56 M929 Event logging is disabled 2020-12-28 00:26:52 M929 P"eventlog.txt" S0 2020-12-28 00:26:44 M929 Event logging is disabled 2020-12-28 00:26:40 M929 P"eventlog.txt" S3 2020-12-28 00:26:32 M929 Event logging is enabled at log level warn 2020-12-28 00:26:28 M929 P"eventlog.txt" S2 2020-12-28 00:26:03 M929 Event logging is enabled at log level info 2020-12-28 00:26:00 M929 P"eventlog.txt" S1
M929 S1 works without problems for me. Note that I entered M118 and accidentally hit return, so I got an error which went into the log. Then I sent
M118 S"Hello" L1
and again it was logged:2020-12-30 19:21:47 Event logging started 2020-12-30 19:22:09 Error: M118: missing parameter 'S' 2020-12-30 19:22:14 Hello
But thanks for pointing out that
M929 S3
isn't working, I'll fix that in the next build. -
@chrishamm Thank you!
Please also note that the log level of S1 and S2 are reversed to what is stated in Gcode documentation.
