Configuration problem?
M574 X1 Y2 Z1 S0
If you are using the same type of switch for all end stops, then X, Y and Z in the above should be the same. If it doesn't stop when triggered, try S1 instead.
As long as you have all switches wired the same way, all should be good. Have you tested continuity of the switch and the wiring to the switch. Also, check that the connector is plugged in to the correct connector. One last thing, when I wired mine up, I didn't get the recepactle in the connector all the way and when I would plug it in to the board, the board pin would push the receptacle out of the plug enough to make it not work.
M574 X1 Y2 Z1 S0
Just changing S0 to S1 will reverse the logic of all the switches. I'm not sure thats what he wants if the other switches are working properly.
Yea the switches light up correctly on the motherboard but the M119 command does not show that it is being triggered. Is there something in the config or .g that I am missing?
Hmmmm…. That is odd. Are you 100% sure you have it plugged in to the Z endstop plug location on the board? I know that sounds basic but stranger things have happened.
Also make sure that you have Z0 in your M558 command.
That SOLVED IT!!!!!!!!!!!!!!!!
Thank You so much!!! I am now Printing and its great can I buy you a beer or 6 @DC42?
