Duet 3/Rpi + toolboard on 3.2b3 - G29 fails
@chrishamm is there any other testing or logs we can provide to assist with this issue?
@chrishamm thanks. I'll be able to test this in about an hour and will report back afterwards..
@chrishamm This is looking promising! It's now 1/3 the way through the same routine that couldn't get past the 1st layer with the previous build.. It should be complete within the next 15 minutes or so.
I can report back afterwards.edit - it just successfully completed. I think it's fixed..
Edit - unless something is obviously wrong in the M122, please dismiss for now. I've rerun this several times and have not been able to reproduce.
@chrishamm @dc42 - this just occurred (or something like it) on 3.2B4.1.
I received the following error:
Error: M280: Response timeout: CAN addr 20, req type 4012, RID=1163 289 points probed, min error -0.065, max error 0.470, mean 0.162, deviation 0.079
M122
=== Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.2-beta4.1 running on Duet 3 MB6HC v0.6 or 1.0 (SBC mode) Board ID: 08DJM-956L2-G43S4-6J1DD-3SJ6S-TB62H Used output buffers: 1 of 40 (40 max) === RTOS === Static ram: 123292 Dynamic ram: 138720 of which 148 recycled Never used RAM 130032, free system stack 128 words Tasks: Linux(ready,83) HEAT(blocked,297) CanReceiv(blocked,837) CanSender(blocked,344) CanClock(blocked,352) TMC(blocked,18) MAIN(running,669) IDLE(ready,19) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:43:58 ago, cause: software Last software reset at 2020-12-09 08:22, reason: User, GCodes spinning, available RAM 130032, slot 0 Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0xffffffff Task Linu Error status: 0x04 MCU temperature: min 29.2, current 40.4, max 40.5 Supply voltage: min 1.5, current 24.2, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 0.2, current 12.1, max 12.2, under voltage events: 1 Driver 0: position 30480, standstill, reads 51957, writes 38 timeouts 0, SG min/max 0/982 Driver 1: position 0, standstill, reads 51973, writes 22 timeouts 0, SG min/max 0/0 Driver 2: position 1030, standstill, reads 51958, writes 38 timeouts 0, SG min/max 0/1023 Driver 3: position 0, standstill, reads 51949, writes 48 timeouts 0, SG min/max 0/474 Driver 4: position 0, standstill, reads 51976, writes 22 timeouts 0, SG min/max 0/0 Driver 5: position 0, standstill, reads 51950, writes 48 timeouts 0, SG min/max 0/1023 Date/time: 2020-12-09 09:06:06 Slowest loop: 999.73ms; fastest: 0.08ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === FreeDm 375 (min 370), maxWait 446390ms, bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves 2007, completed moves 2007, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 5], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.5 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === CAN === Messages queued 15276, send timeouts 44, received 37057, lost 0, longest wait 2ms for reply type 6031, free buffers 47 === SBC interface === State: 0, failed transfers: 0 Last transfer: 18ms ago RX/TX seq numbers: 34609/34610 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x209ac Buffer RX/TX: 0/0-0 === Duet Control Server === Duet Control Server v3.2.0-beta4 Code buffer space: 4096 Configured SPI speed: 8000000 Hz Full transfers per second: 38.07
M122 B20
Diagnostics for board 20: Duet TOOL1LC firmware version 3.2-beta4.1 (2020-12-03) Bootloader ID: SAMC21 bootloader version 2.1 (2020-11-03b2) Never used RAM 4208, free system stack 72 words HEAT 50 CanAsync 89 CanRecv 83 TMC 54 MAIN 216 AIN 64 Last reset 00:44:32 ago, cause: power up Last software reset data not available Driver 0: position 0, 830.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 12, reads 25496, writes 12, timeouts 0, DMA errors 0 Moves scheduled 0, completed 0, in progress 0, hiccups 0 No step interrupt scheduled VIN: 24.2V MCU temperature: min 32.5C, current 56.5C, max 58.1C Ticks since heat task active 237, ADC conversions started 2661831, completed 2661830, timed out 0 Last sensors broadcast 0x00000002 found 1 241 ticks ago, loop time 0 CAN messages queued 37596, send timeouts 0, received 28817, lost 0, free buffers 36
