Two stepper motors in parallel
@maddy said in Two stepper motors in parallel:
@dc42 I want to use 2 Nema 23 high torque motors for the y-axis with Duet 3MB 6HC and 32v power supply. Will the series connection of such motors work with the default drivers of Duet 3? If not, how can I fix 2 motors for y-axis? Do I need any additional board for another motor of y-axis?
If you connect them in series, then at high speeds that will limit the available torque and increase noise. Better to connect them to separate driver outputs.
@dc42 said in Two stepper motors in parallel:
If I understood properly, I don't need any expansion board for additional drivers. is that right?. My Duet 3 6HC can support 2 motors for y-axis, 1 motor for each x-axis and z-axis, and 1 for the extruder motor. e.g. M584 X0 Y1:2 Z3 E4.
Please correct me if that is not right. thank you for your prompt response. -
Please correct me if that is not right. thank you for your prompt response.That's correct
@jay_s_uk thank you
