Automatic Bed Leveling with Conditional Gcode Iterations
@bearer said in Automatic Bed Leveling with Conditional Gcode Iterations:
already were in relative mode you would not return to absolute in error
If I'm understanding correctly; If you are in currently in relative positioning and then you issue a G91 again - it would toggle, putting you in absolute positioning?
@Kolbi said in Automatic Bed Leveling with Conditional Gcode Iterations:
G90 sets the mode to absolute. Sending it again changes nothing.
G91 sets the mode to relative. Sending it again changes nothing.
Ok, rgr that. So given the following:
M120: Push Example M120 Push the state of the machine onto a stack. Called automatically when a macro file is run. It pushes the following values on the stack: Current feedrate Extruder positions Whether moves (and separately extrusion) are relative or absolute M121: Pop Example M121 Recover the last state pushed onto the stack.
Could use M120 before issuing any homing related current/sensing changes and then instead of changing them all back via individual commands - just use M121? I'm thinking no, but figure it doesn't hurt to ask.
I guess what I'm trying to figure out and ask is, what exactly is saved in the 'stack'? Also, the documentation states that M120 is called automatically when a macro file is run - I assume this means any gcode file that resides in the macros directory and that this would not apply to files in the sys directory?
BTW, @fcwilt & @bearer Thanks for helping me understand this.
...Maybe if I get one of these, all will be clear -
I've never used Push & Pop.
Yes there are places where I switch to relative (G91) and shortly thereafter switch back to absolute (G90) but not that many places, primarily in the homing macros.
If you were to look at all of the .g files in my sys directory the numbers of G90s or G91s would be small in comparison with all the other code.
I've simply never worried about it - I use them as needed.
Thanks @fcwilt, much like what you have stated - I have never used M120/1 and haven't had any issues.
But on the other side of the coin, it makes me wonder if I could/should be doing things better by employing it's use? It seems to me, with my limited duet experience, that such command would be most usefully employed by a macro being called while performing an actual print, so that the desired settings set by the slicer would 'pick up where the macro leaves off' & not so important while performing homing evolutions before a print is started.
I don't rely on the commands my slicer sets at the beginning of a print.
Here is my "print begin" macro called by the slicer at the beginning of a print.
None of those slicer commands matter because my code overrides them all.
; S3D inserts the following 5 lines of code just before calling this file ;G90 ; absolute XYZ moves ;M83 ; relative E moves ;M106 S0 ; fan off ;M140 S60 ; bed temp to 60 ;M104 S190 T0 ; extruder temp to 190 M98 P"test_if_homed.g" ; aborts print if not homed T0 ; select tool 0 so extruder commands below will work M703 ; configure selected filament (sets bed/extruder temps) M106 P2 S255 ; lights on M106 P3 S255 ; lights on M106 P4 S255 ; lights on G90 ; absolute moves G1 Z75 F1200 ; position for cleaning G1 X0 Y-145 F6000 ; position for cleaning M291 R"Heating Extruder/Bed" P"Please wait..." T0 M116 ; wait for temps to reach set points M291 R"Priming Extruder" P"Please wait..." T0 G92 E0 ; reset the extruder logical position M83 ; extruder relative mode G1 E10 F120 ; prime the extruder M400 ; wait for extruding to finish G92 E0 ; reset the extruder logical position M291 R"Clean Nozzle and Bed" P"Click OK to begin printing" S3 M98 P"mesh_comp_map_load.g" ; load height map based on height map mode
@fcwilt Thanks for that info. Could you achieve the same thing by use of start.g? If not the same because timing with regards of being called by the slicer, what does your start.g contain?
Many thanks,
Kolbi -
Many thanks,
KolbiI haven't gotten around to determining exactly when start.g executes, just too many things on my plate.
My current system works but I imagine converting it to rely on start.g would not be a problem.
@fcwilt said in Automatic Bed Leveling with Conditional Gcode Iterations:
I totally understand that. Thanks again for sharing all the info.
Cheers,
Kolbi -
I updated the first initial post to give a 'bottom line up front', the two efficient ways that were created to level the gantry, for ease of use.
Normally I invoke PRINT_BEGIN.g and PRINT_END.g from within the slicer using whatever feature the slicer provides.
START.g was called before the call to PRINT_BEGIN.g. That seems to happen automatically without any action on part of Simply3D (S3D).
PRINT_BEGIN.g was called because I invoked it within S3D in the "Starting Script" option on the "Scripts" tab.
STOP.g was not called at all. It seems the slicer must insert a M0 command at the end of the print to invoke STOP.g.
PRINT_END.g was called because I invoked it within S3D in the "Ending Script" option on the "Scripts" tab.
Since I want a "end of print" macro to execute, without a way to force the slicer to include M0 at the end I will stick with the "Script" options and invoke PRINT_BEGIN.g and PRINT_END.g
If would be nice if START.g and STOP.g would execute without any action on the part of the slicer. Then I could dispense with insuring the slicer invokes PRINT_BEGIN.g and PRINT_END.g
@fcwilt I understand, thanks!
there is also this overview https://duet3d.dozuki.com/Wiki/Macros#Section_System_Macros
Thanks - I had not seen that.
I use start.g for general print prep. Homing, preheat. Then it passes off to the slicer for setting the temps for the print. Then in the slicer start gcode section it calls a macro to print a prime line and then start the print. I do it this way so that the prime line is printed at the right temp for the material being used.
The slicer end gcode just contains M0 and then stop.g has all of the actual end of print commands.
I kind of wish there was just an end.g that could take the place of M0 -> stop.g
@Phaedrux said in Automatic Bed Leveling with Conditional Gcode Iterations:
As you may have noticed in my print_begin.g macro I rely on the filament feature to set bed/filament temps.
I do wait for the temps to be reached before starting to print. I don't know what a "prime line" is - I just print a 2 line skirt so I can watch to see how the first layer is going down and adjust baby-stepping or abort, as needed.
"prime line"
In my case:
;M98 P"0:/sys/PrimeNozzle.g" G90 ; Absolute positioning G1 X1 Y270 F6000 ; Move to rear left corner M400 ; clear movement buffer M116 ; Wait for temps G1 Z0.3 F100 ; Move Z to prime height G91 ; Relative positioning M83 ; Relative extrusion G1 X40 E10 F300 ; Prime nozzle G10 ; Retract G1 Y-1 X1 F10000 ; Wipe nozzle M400
And start.g since we're being transparent.
M106 P2 F30000 S0.5 H-1 C"Duet Fans" M140 S65 ; set heated bed to 65 and release T0 ; Select Tool 0 M291 P"Print Started. Preheating and Homing." T10 G4 S1 M98 P"0:/macros/Musical Tunes/LuckyTune.g" ; Lucky tune to start print off on the right foot G4 S1 M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed M290 R0 S0 ; clear babystepping M106 S0 ; Turn part cooling blower off if it is on G10 P0 R0 S80 ; Set extruder to 80 and release M190 S65 ; set heated bed to 65 and wait G28 ; home XYZ G29 S1 ; load heightmap M400 G10 P0 R80 S180 ; Set extruder to 180 and release M98 P"0:/sys/ZSpeedsPrint.g" ; Load Z speeds for printing M98 P"0:/sys/CurrentsPrint.g" ; Load print motor currents ; Slicer Start Gcode begins.
and stop.g for the hell of it.
; stop.g ; called when M0 (Stop) is run (e.g. when a print from SD card is cancelled) ; Also called by slicer end gcode by M0 ; M400 ; Finish move queue M104 S0 ; Extruder heater off M140 S0 ; Bed heater off M106 S255 ; Fan at 100 to cool nozzle and bed G91 ; Relative positioning M220 S100 ; Set speed factor back to 100% in case it was changed M221 S100 ; Set extrusion factor back to 100% in case it was changed G1 E-2 F9000 ; Retract filament 2mm G1 X5 Y5 F9000 ; Wipe nozzle G1 Z20 F500 ; raise nozzle 5mm from printed part G90 ; absolute positioning G1 X150 Y130 F6000 ; Move x and Y axis over to bed center so probe is on top of bed ;M104 S35 ; Set hot end low and wait G4 S60 ; Wait 5 minutes ;M116 ; wait for temp to drop G28 X Y ; Home X and Y G28 X Y ; Home it again, Sam. M290 R0 S0 ; clear babystepping M84 ; Steppers off M98 P"ZSpeedsNormal.g" ; Load normal z speed settings again. M106 S0 ; Fan off M106 P2 F30000 L0.1 X0.8 B0.5 T35:70 H100:101:102 C"Duet Fans" ;Play a little beep beep beep to show print ended. M400 ; Clear queue again before jingle G4 S1 M300 P250 S750 G4 P251 M300 P200 S1250 G4 P201 M300 P250 S750 G4 P251 M300 P200 S1250 G4 P201 M300 P250 S2500 G4 P251 M300 P150 S2000 G4 P151 M300 P150 S2500 G4 P151 M300 P350 S3700 G4 P351
@Phaedrux Thanks for sharing. Do you use filament/config.g or just use slicer start code?
I haven't used the filaments function for a long time. I use prusa slicer and cura interchangeably. I use prusa slicer for the filaments library and refer to it when I'm setting up a print in Cura.
