Software bundle 3.1.1 now available
the update to 3.10 worked well, unfortunately my PanelDue 7 "no longer wants to connect to my duet2maestro
there are already solutions for this Problem?
thank you -
@Macwolf said in Software bundle 3.1.0 now available:
https://github.com/Duet3D/RepRapFirmware/blob/v3-dev/WHATS_NEW_RRF3.md#reprapfirmware-310
8.5h print - done, flawless (few small ones done before it)
5/16/2020, 8:30:07 PM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3SD6Q-KVRBF Used output buffers: 3 of 24 (14 max) === RTOS === Static ram: 28180 Dynamic ram: 93784 of which 32 recycled Exception stack ram used: 568 Never used ram: 8508 Tasks: NETWORK(ready,76) HEAT(blocked,1168) MAIN(running,1880) IDLE(ready,80) Owned mutexes: === Platform === Last reset 21:14:17 ago, cause: power up Last software reset at 2020-05-15 22:30, reason: User, spinning module GCodes, available RAM 9356 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 10 MCU temperature: min 28.5, current 35.4, max 37.0 Supply voltage: min 23.0, current 24.0, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: ok, SG min/max 0/367 Driver 1: ok, SG min/max 0/411 Driver 2: standstill, SG min/max 0/435 Driver 3: ok, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2020-05-16 20:30:07 Cache data hit count 4294967295 Slowest loop: 604.84ms; fastest: 0.13ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 9 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 5.3ms, write time 617.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 157, MinFreeDm: 104, MaxWait: 44825051ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 1381801, completed moves: 1381761, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: 3 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.8 === GCodes === Segments left: 1 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is doing "G1 E0.1000 F3000" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 617.56ms; fastest: 0.02ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: no data received 5/16/2020, 9:12:44 PM Finished printing file 0:/gcodes/Body_high_detail.gcode, print time was 8h 28m 5/17/2020, 1:10:04 AM M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 3.1.0 running on Duet Ethernet 1.02 or later Board ID: 08DGM-9T6BU-FG3S4-6J9FD-3SD6Q-KVRBF Used output buffers: 1 of 24 (19 max) === RTOS === Static ram: 28180 Dynamic ram: 93784 of which 32 recycled Exception stack ram used: 568 Never used ram: 8508 Tasks: NETWORK(ready,76) HEAT(blocked,1168) MAIN(running,1880) IDLE(ready,80) Owned mutexes: === Platform === Last reset 25:54:14 ago, cause: power up Last software reset at 2020-05-15 22:30, reason: User, spinning module GCodes, available RAM 9356 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0441f000 BFAR 0xe000ed38 SP 0xffffffff Task MAIN Error status: 10 MCU temperature: min 31.6, current 35.1, max 35.7 Supply voltage: min 23.4, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes Driver 0: standstill, SG min/max 0/315 Driver 1: standstill, SG min/max 0/383 Driver 2: standstill, SG min/max 0/405 Driver 3: standstill, SG min/max 0/1023 Driver 4: standstill, SG min/max not available Date/time: 2020-05-17 01:10:04 Cache data hit count 4294967295 Slowest loop: 79.29ms; fastest: 0.14ms I2C nak errors 0, send timeouts 0, receive timeouts 0, finishTimeouts 0, resets 0 === Storage === Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest read time 2.0ms, write time 0.0ms, max retries 0 === Move === Hiccups: 0(0), FreeDm: 169, MinFreeDm: 109, MaxWait: 14ms Bed compensation in use: mesh, comp offset 0.000 === MainDDARing === Scheduled moves: 1498329, completed moves: 1498329, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === AuxDDARing === Scheduled moves: 0, completed moves: 0, StepErrors: 0, LaErrors: 0, Underruns: 0, 0 CDDA state: -1 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 -1 -1 Heater 0 is on, I-accum = 0.0 Heater 1 is on, I-accum = 0.7 === GCodes === Segments left: 0 Movement lock held by null HTTP is idle in state(s) 0 Telnet is idle in state(s) 0 File is idle in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger is idle in state(s) 0 Queue is idle in state(s) 0 Daemon is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 7.02ms; fastest: 0.06ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions HTTP sessions: 1 of 8 Interface state active, link 100Mbps full duplex === Filament sensors === Extruder 0 sensor: no data received
We have just published a bug fix release following the initial 3.1.0 release so the first post has been updated. This will fix potential network problems on the Duet 2 series and inconsistent code execution on the Duet 3 series in SBC mode. Apart from that, a few bugs problems have been fixed in DWC2. See the release notes in the main post for further details.
if your using Duet Wifi v1.04, which firmware package do i use?
Duet2and3Firmware-3.1.1.zip
OR
Duet2CombinedFirmware.bin
regards,
Tony.
@turbo3000 It will depend on what firmware version you're coming from.
You should probably go from 2.05.1 to 3.0 to 3.1.1
And it would be the zip file from those releases which contains the firmware bins, the DWC files, and everything else needed all together in the zip file.
thankyou.
i got FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 2.03beta3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2019-03-25b6
so 2.05.1, then 3.0 & then 3.1.1
A pitty i couldn't upgrade direct to 3.1.1
@turbo3000 said in Software bundle 3.1.1 now available:
You could if you used the USB flash method using bossa, but if you want to just upload 3 zip files to the web interface, the progression is required so that the programming files are in place.
Plus if you used the USB method, you'd still need to make sure the IAP programing files are on the SD card so that future firmware updates work, and you'd still have to update DWC either manually or by upload.
So in the end, uploading 3 zip files in a row isn't too bad.
Also keep in mind that you'll need to update your config.g quite a bit for compatibility with RRF3. In fact it may be best to get a fresh config from the web configurator to ensure you have a working base to build on.
@Phaedrux said in Software bundle 3.1.1 now available:
i could be wrong, but uploading 1 zip file, answer "no" to doing the upgrade in dwc and then running bossa could be the shortest possible path, but limited testing admittedly.
