Stepper issues
@Phaedrux the firmware upload I suspect has locked up, I have “please wait while updates are being installed...” there are no system files on display and it’s been at least 30mins so far is there anything I can do or should I just wait?
Seeing as you're using the raspberry pi I believe the means of updating would be to use apt update on the pi. I believe you'd also need to have the unstable repository added.
https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
@Phaedrux does that not only apply to raspbien? I’m running duetpi running sudo update/upgrade was one of the first things I did when I installed the board.
I think you'd still need the unstable repository added to get the latest.
@Phaedrux i think it did it, i ran M115 again and got this -
M115
FIRMWARE_NAME: RepRapFirmware for Duet 3 MB6HC FIRMWARE_VERSION: 3.01-RC6 ELECTRONICS: Duet 3 MB6HC v0.6 or 1.0 FIRMWARE_DATE: 2020-04-03b3hopefully this will help solve some issues, thank you for your help its much appreciated
