No output from G32 on DSF 1.2.4 / DWC 2.07
@kraegar said in No output from G32 on DSF 1.2.4 / DWC 2.07:
I strongly recommend using a script to auto level until it's under a set value, with a Z home at the end
That is exactly what I do. And check the console output to see that it is converging.
Literally called "prepz.g"
@chrishamm This is indeed correctly working now in DSF 1.3.1. Great job! Thanks! As this was the original issue, I guess this topic can be closed now.
@chrishamm Just to make sure I'm not doing anything wrong...conditional gcode is not yet in dsf 1.3.1, correct?
This has been driving me crazy for months - can confirm console output is restored for G32 (and others for me) with with 2.1.1
Thank you.
