Duet 3 32v on 3D printer?
@bearer said in Duet 3 32v on 3D printer?:
i think the 0.00132 value is the total capacitance for the main board. you'd need to calculate that for the expansion as it also has fewer capacitors
Correct.
@dc42 Does the firmware support diffrent voltage on Duet 3 6HC and connected 3HC expansion?
@TypQxQ said in Duet 3 32v on 3D printer?:
Yes. And a different input voltage for OUT0 on the MB6HC too.
Just an update.
It works great and my Meanwell LRS-350-36 can be turned down to 30V with the builtin regulator.
Now runing this on the 3HC expansion:
VIN: 30.9V, V12: 12.2V -
Interesting; i had to mod my SE-450 supply as it would only do 32.4 to 39.6V.
Per previous posts, hope I got correct.
6HC and 3HC can use different volts from each other. (in same system)
Mentions of hacking boards to get higher voltages means problems with 5v and 12v.
If my 3HC is only used for X and Y motors, could I modify my 3HC to use 36v or even 48v?
All sensors / fans / end stops etc.. would be from the 6HC.
Other option is 6HC + (1x) 1XD per axis along with “CNC style” separate drivers then motors.
Thanks!
`mike -
@gallaghersart said in Duet 3 32v on 3D printer?:
Yes, in principle. You would need to remove the diode that feeds fused VIN to the 12V and 5V regulators. Then feed 12 or 24V to the pad that the diode cathode was connected to, so that the onboard regulators can supply 12V to the drivers and 5V to the MCU etc.
The capacitors connected to the VIN supply to the drivers are rated at 50V. So 48V is too close, bearing in mind that when you turn the motors off they feed power back into the supply, causing an increase in supply voltage.
Cool, thanks!
Still several weeks away from getting this printer up and running, will start with 24v to get all working.
Then I will test and share. Burn or Good should be fun.
Will investigate see how low I can adjust a 48v and then do the math.
`mike -
So just to check that my working out is correct for this stepper with Inductance of 1.85 mH, using dc42's formula from above; sqrt(V^2 + n * (L/C) * I^2)
M906 current set at 4a
sqrt(3636 + 4(0.00185/0.00132) * 4 * 4) = 36.00000217066660122509v
I just want to be sure that this is right, because it seems that adjusting the amount of motors doesn't seem to change the result much?
