Fourth Extruder not working on latest RRF3
@dc42 said in Fourth Extruder not working on latest RRF3:
@smoki3 said in Fourth Extruder not working on latest RRF3:
This is now fixed. Source files have been committed, and new binaries are in the same place as before. Thanks for reporting it.
I noticed that there is still something wrong. The 4 extruder is now active but it moves now simultaneous with every single axis movement.
Means when I move 100mm in Y axis it also extrudes 100mm, if I move -100mm in Y it retracts 100mm. And this also happens when I move in X and Z axis. Really wired behavior.
Just happens on the 4th extruder again. Looks like the driver 6 is know linked to all other axes
Is that with the binary on dropbox that I linked to?
PS:
- I can't reproduce that issue with the binary I built last night.
- What mapping does M584 report?
I also have tried now M584 X0 Y1 Z2 E6:4:5:3 U7
then driver 3 is running in sync with the axis. So looks like it is also not related to the driver.
Steps to reproduce:
- Select a tool
- wait for heating up
- extrude a few mm manually
- the move the axis
On beta12 still every thing is fine with same configs
I've just fixed this - new binary in same place as before.
Tested with the dropbox binary. Now it's working. Thanks
