No x move with G1 X147 F6000
@PuddingBaer91 said in No x move with G1 X147 F6000:
ok i did a complete reconfig with the online tool and firmware 2.03... Now almost is running fine except homing z. If i press home all x axis moves to the correct location x=220 but y moves always to y=30. I can't find the error...
Does it home correctly to Y=+335 before going to Y30 instead of to Y157? If so then I suspect that your M92 Y steps/mm value is incorrect. Try jogging Y 10mm or 50mm at a time in Duet Web Control, and see how far it actually moves.
if i move the head with web control it moves correctly. As you said i move to y=335. After homing is done it shows y=335 at web control. Steps per mm should be correct. Calculated with prusa calculator and these values i used for many months.. X and Y are the same motors and pulleys also the steps/mm should be equal.
Your M558 command indicates that you have a BLTouch. You should remove the M98 Pdeployprobe.g and M98 Pretractprobe.g lines. Also, check that your deployprobe.g and retractprobe.g files are set up correctly for BLTouch.
