Tool Change: Moving in axis without calling them
So I also tried a M400 in the first line of the tpre script. Then everything is fine
I also noticed that you have this diagonal movement when you dock your tool after the print. But as Danal mentioned it only happen if directly after the tfree script a G1 follows.
@smoki3 said in Tool Change: Moving in axis without calling them:
Thanks, from that I think I know what is going on, and I can fix it in 3.0 release.
@dc42 said in Tool Change: Moving in axis without calling them:
Cool! So please also merge it to 2.xx
@smoki3, I have fixed this in the 3.0 stable release.
I am not planning to do any further 2.x releases, but you have an easy workaround (M400 at the start of the tpre and/or tpost file).
I see. Its working fine now.
For 2.x I don't use it. I just thought about all the tool changer users....
