New firmware 1.18RC1
I've just released firmware 1.18RC2. I am particularly keen for Duet 0.6/0.8.5 users to test it, to see if it resolves the network issues that some users had with beta3 and RC1.
ChrisP, thanks for your patience. Please can you try the Duet06/085 firmware at https://dl.dropboxusercontent.com/u/19369680/RepRapFirmware.bin and let me know if you have stability problems with it. If you find that you are unable to connect via HTTP at all, then please run M122 from USB and report the Network section of the diagnostic report.
No problem.
I updated a couple of Duet 06 boards at work to 1.18RC2 and disabled Telnet and haven't had any stability problems since. Unusually, I haven't actually used those printers in the past day or so, but they have been left on 24/7 and I haven't had any problems connecting via HTTP. I'll try the FW in your link anyway, in particular with my old Duet 06 at home that I never managed to get to work on anything beyond 1.17e. -
ChrisP, I think I found the problem. Does your home network have a zero in the IP addresses it uses?
Yes it does. 192.168.0.x
Thanks for confirming that. The problem is fixed in the 1.18 release.
