Weird Bed Mesh Behavior after Z-Leveling
Here is the correct data:
config.g: https://github.com/natewalck/railcoreiiduet/blob/master/300ZL/sys/config.g
homeall.g: https://github.com/natewalck/railcoreiiduet/blob/master/300ZL/sys/homeall.g
homex.g: https://github.com/natewalck/railcoreiiduet/blob/master/300ZL/sys/homex.g
homey.g: https://github.com/natewalck/railcoreiiduet/blob/master/300ZL/sys/homey.g
homez.g: https://github.com/natewalck/railcoreiiduet/blob/master/300ZL/sys/homez.gDoing the same exact process as in post # 18 (with the bed showing 0.1 too low):
And here is the M122 output after each command:
After G28:
0_1561083216074_M122_after_G28.txt
After G32 run 1:
0_1561083226991_M122_after_G32x1.txt
After G32 run 2:
0_1561083235889_M122_after_G32x2.txt
After G28 Z:
0_1561083244610_M122_after_G28_Z.txt
After G29 command (As shown above):
0_1561083256472_M122_after_G29.txt
As you can see, the bed still appears ~ 0.1mm too low using the above sequence.
Also, I don't see "comp offset" anywhere in the M122 outputs. It shows no bed compensation being used at all.
Thanks!
Nate
@natewalck said in Weird Bed Mesh Behavior after Z-Leveling:
I guess you are not using firmware 2.03 then. Please repeat the tests using firmware 2.03.
When you home Z, you probe first at 500mm/min then at 50mm/min. What probing speed do you use when you run G29?
Edit: also you are using an old beta firmware version, which is unsupported.
