New firmware 2.03RC2 available
@dc42 did you see my post above regarding m291?
@gavatron3000 said in New firmware 2.03RC2 available:
There is a problem in supporting M291 commands that require acknowledgement or allow axis movement within tool change files. If the tool change command is sent from DWC or PanelDue, then RRF is executing that command for that channel until the tool change is complete. That means that it cannot execute an axis jog command or M292 acknowledge command that comes from the same channel as the tool change command. This is what causes the firmware to lock up in the tool change. If you send M292 from another device, it continues.
ok no worries are we able to support it at the end of tpre and tfree instead?
Not easily, because the tool change sequence isn't complete until tpost has completed.
I've just released firmware 2.03RC3 so I am locking this thread.
