RepRapFirmware 3.0
@mudcruzr said in RepRapFirmware 3.0:
P.S. @bearer - I didn't have to change anything for my dual Z motors to work
I didn't say it worked in 2.03
Anyways pretty sure you should only need the commands once in config.g. Maybe its a ordering of things thing, I haven't studied the changes in too much detail, but when putting it at the way bottom of config.g it seems to work.
@bearer said in RepRapFirmware 3.0:
Lol!
I tried the M950 command as the very last line in my config.g and it didn't work, I also can't see anything in config-override.g that would change it. So I think it's a question for @dc42
@dc42 David, where must the M950 command reside? I have it as the very last command in my config.g but in order to use my bltouch probe I must also put it in the deployprobe.g file immediately before the M280 for it to work.
After the deployprobe.g file has run once, I don't need to put M950 anywhere else, everything just works. Are there any rules about where it must be either before or after certain other commands?
Putting the M950 command at the end of config.g should work. The rules are:
At the point where you run M950, the pin you are assigning must be free. So you must cancel any default or previous assignment before the M950 command.
The M950 command must be executed before the command that uses the mapping it sets up - so in your case, before the first M280 command is executed.
It may help to run M98 P"config.g" so that you can see any errors that are thrown when config.g executes.
No errors from config.g but I now have the probe working. I hadn't put the C"zprobe.in" in the M558 line because the probe was working without it (as long as the M950 was still in deployprobe.g). As soon as I added the C"zprobe.in" everything started working as it should. The M558 line is now:
M558 P9 C"zprobe.in" H5 F300 T4000 A10 S0.003 R0.5 B1
And M950 S0 C"zprobe.mod" is the last line in my config.g and nowhere else.
Thanks guys.
@mudcruzr Would you care to share your config.g please. I have been looking to upgrade to RRF3 but need a template to work from!
TIA Paul. -
@paulhew said in RepRapFirmware 3.0:
TIA Paul.Sure, here you go:
0_1557820856402_config.gEdit: I should mention that I have 2 separately controlled Y motors and 2 separately controlled Z motors.
I've modified my Maestro 12864 menu files to work with RRF3b1, but to avoid confusion I've created a separate new repository on Github for them. There are no changes to functionality yet, they do the same as before but work with RRF3.
Here they are: https://github.com/mudcruzr/Duet-Maestro-12864-Menu-Files-for-RRF3b1/releases/tag/v0.1.RRF3b1
Should you not be able to use M401 instead of M280 to keep the menu files the same? I thought M401 called M98 P"deployprobe.g" which then can ve version specific?
@mudcruzr Thank you, greatly appreciated.
Yes I saw the Y and Z's in the code and did wonder!Time to back everything up and try it!
Thanks again.
Paul -
I guess I could, but I expect RRF2 and RRF3 to diverge more and more as RRF3 develops and trying to include new RRF3 functionality while maintaining backwards compatibility with RRF2 seems a bit like making a rod for my own back. I fully expect the whole lot to be rewritten & redesigned more than once.
Thanks guys.
I can see why. The default pin configuration for M558 is "zprobe.in+zprobe.mod". For your M950 command to work, the zprobe.mod pin must be free. So you need to redefine the Z probe pins as just "zprobe.in" in M558, to free up the "zprobe.mod" pin.
M401 does a little more than that, it also records the Z probe as being deployed. This means that when you come to do a G30, the firmware knows that the probe is deployed, so it doesn't do an automatic deploy/retract around the G30 command. This can be used to deploy the probe just once at the start of bed.g and retract the proibe just once at the end. [This doesn't work for BLTouch, which needs to be deployed/retracted at every probe point.]
So M401 should always be used in preference to M98 Pdeployprobe.g, and similarly M402 instead of M98 Pretractprobe.g.
@dc42 just did a git pull to get your latest v3-dev changes and just fyi... auto bed levelling is still non-automatic. Calculations are done but no movement.
If you don't have time to look at it right now, that's cool. I can take a look this weekend.
@gtj0 said in RepRapFirmware 3.0:
Does it work properly on your printer using 2.03RC2 ?
@dc42 said in RepRapFirmware 3.0:
I just double checked and yes it works on 2.03RC2. It does the 3 probes, calculates the offsets, then adjusts the motors to compensate.
@gtj0, thanks for confirming this. I will invesgigate the issue RRF3.
I think I have found the reason for leadscrew moves not working. I have pushed some updates to the RRF 3 source. Please note, I have also made some changes to the M558 command.
Working now, thanks!
Is there any chance of a new build with these changes in (for those of us without the wherewithall to compile) please?
New binaries here https://www.dropbox.com/s/fyvibzm0zl92hiy/Duet2CombinedFirmware.bin?dl=0 and here https://www.dropbox.com/s/m0r3ldy424mxf4v/DuetMaestroFirmware.bin?dl=0.
