Laser monitor
M563 P1 S"1xHotend" D0 H1 ; Define tool 1
G10 P1 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
M563 P2 S"2xHotend" D1:0 H2:1 ; Define tool 2
G10 P2 X0 Y0 Z0 ; Set tool 2 axis offsets
G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
M568 P2 S1 ; Enable mixing for tool 2
M567 P2 E1:1 ; Set mixing ratios for tool 2
M563 P3 S"3xHotend" D2:0:1 H3:1:2 ; Define tool 3
G10 P3 X0 Y0 Z0 ; Set tool 3 axis offsets
G10 P3 R0 S0 ; Set initial tool 3 active and standby temperatures to 0C
M568 P3 S1 ; Enable mixing for tool 3
M567 P3 E1:1:1 ; Set mixing ratios for tool 3
M563 P4 S"4xHotend" D3:0:1:2 H4:1:2:3 ; Define tool 4
G10 P4 X0 Y0 Z0 ; Set tool 4 axis offsets
G10 P4 R0 S0 ; Set initial tool 4 active and standby temperatures to 0C
M568 P4 S1 ; Enable mixing for tool 4
M567 P4 E1:1:1:1 ; Set mixing ratios for tool 4
;M563 P5 S"5xHotend" D4:0:1:2:3 H5:1:2:3:4 ; Define tool 5
;G10 P5 X0 Y0 Z0 ; Set tool 5 axis offsets
;G10 P5 R0 S0 ; Set initial tool 5 active and standby temperatures to 0C
;M568 P5 S1 ; Enable mixing for tool 5
;M567 P5 E1:1:1:1:1 ; Set mixing ratios for tool 5
M563 P11 S"1xHotend300" D0 H1 ; Define tool 11
G10 P11 X0 Y0 Z0 ; Set tool 11 axis offsets
G10 P11 R0 S0 ; Set initial tool 11 active and standby temperatures to 0C
M563 P12 S"2xHotend300" D0:1 H1:2 ; Define tool 12
G10 P12 X0 Y0 Z0 ; Set tool 12 axis offsets
G10 P12 R0 S0 ; Set initial tool 12 active and standby temperatures to 0C
M568 P12 S1 ; Enable mixing for tool 12
M567 P12 E1:1 ; Set mixing ratios for tool 12
;M563 P13 S"3xHotend300" D1:0:2 H1:2:3 ; Define tool 13
;G10 P13 X0 Y0 Z0 ; Set tool 13 axis offsets
;G10 P13 R0 S0 ; Set initial tool 13 active and standby temperatures to 0C
;M568 P13 S1 ; Enable mixing for tool 13
;M567 P13 E1:1:1 ; Set mixing ratios for tool 13
;M563 P14 S"4xHotend300" D0:1:2:3 H1:2:3:4 ; Define tool 14
;G10 P14 X0 Y0 Z0 ; Set tool 14 axis offsets
;G10 P14 R0 S0 ; Set initial tool 14 active and standby temperatures to 0C
;M568 P14 S1 ; Enable mixing for tool 14
;M567 P14 E1:1:1:1 ; Set mixing ratios for tool 14M563 P91 S"1xHotend" D0 H1 ; Define tool 1
G10 P91 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P91 R0 S0
M563 P92 S"1xHotend" D1 H2 ; Define tool 1
G10 P92 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P92 R0 S0
M563 P93 S"1xHotend" D2 H3 ; Define tool 1
G10 P93 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P93 R0 S0
M563 P94 S"1xHotend" D3 H4 ; Define tool 1
G10 P94 X0 Y0 Z0 ; Set tool 1 axis offsets
G10 P94 R0 S0
;M563 P95 S"1xHotend" D4 H5 ; Define tool 1
;G10 P95 X0 Y0 Z0 ; Set tool 1 axis offsets
;G10 P95 R0 S0; Lasersensor
M591 D1 P5 C4 R40: 120 E3.0 S1 ; Der Duet3D-Lasersensor für den Extruderantrieb 0 ist an den Stopp-Eingang 3 (E0) angeschlossen, Toleranz 40 bis 120%, 3 mm Vergleichslänge
M591 D2 P5 C3 R40: 120 E3.0 S1 ; Der Duet3D-Lasersensor für den Extruderantrieb 0 ist an den Stopp-Eingang 3 (E0) angeschlossen, Toleranz 40 bis 120%, 3 mm Vergleichslänge
M591 D3 P5 C0 R40: 120 E3.0 S1 ; Der Duet3D-Lasersensor für den Extruderantrieb 0 ist an den Stopp-Eingang 3 (E0) angeschlossen, Toleranz 40 bis 120%, 3 mm Vergleichslänge
M591 D4 P5 C1 R40: 120 E3.0 S1 ; Der Duet3D-Lasersensor für den Extruderantrieb 0 ist an den Stopp-Eingang 3 (E0) angeschlossen, Toleranz 40 bis 120%, 3 mm Vergleichslänge
;M591 D9 P5 C2 R40: 120 E3.0 S1 ; Der Duet3D-Lasersensor für den Extruderantrieb 0 ist an den Stopp-Eingang 3 (E0) angeschlossen, Toleranz 40 bis 120%, 3 mm Vergleichslänge -
Which tool number did you use for that test print?
@dc42 tool 1
@dc42 on the D0 according to the readout no sensor is installed and the D1 reads it actually clean
@3dware said in Laser monitor:
@dc42 tool 1
From your config.g file:
The D0 means you are using extruder drive 0. Your M591 command has D1, so it is monitoring extruder drive 1.
@dc42 Only I do not get anything out at d0
I plugged in the sensors like this.
I have aninst somewhere a mistake
I think your mistake is this line:
The sensor is monitoring extruder drive 1, but tool 1 uses extruder drive 0. Change D1 to D0 in that line. Likewise when you interrogate it, use D0 not D1.
Thank you very much for your quick help.
as always.
regards
hello dc42
I still have a small mistake that you can possibly explain to me.
Soblad the filament is empty, the printer goes into pause.
if I then unload the macros and load and then continue to print the laser is no longer.
that means when I cut the filament he does not recognize more than empty.how can I fix this?
I'm sorry, I don't understand - please explain what you mean.
