Fan channel help
Hello. I need help. I burned part cooling channel. how to assign another channel.
You can connect the part cooling fan to the Fan2 output instead. Then add parameter F2 to your M563 command(s) in config.g. The effect of that will be that whenever a tool is selected, any M106 command with no P parameter will be routed to Fan 2.
Like this
M106 P2 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S200 I0 F100 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P0 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off; Tools
M563 P0 D0 H1 F2 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C -
yes it works. thanks
