Resolved Print hangs
It's odd that you are getting a software reset. Please post your config.g file just in case I can spot anything.
So PSU ruled out, exactly the same results with a Stabilised 12v bench supply, with and without USB
Note: I added in the heat calibration at the end as I did get some messages about taking to long.
; Configuration file for Duet WiFi
; generated by RepRapFirmware Configuration Tool on Wed Nov 23 2016 20:59:26 GMT+0000 (GMT Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like Marlin
M208 X195 Y170 Z180 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z1 S0 ; Define active low and unused microswitches
M558 P1 X0 Y0 Z1 H10 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P500 X0 Y12 Z1.0 ; Set Z probe trigger value, offset and trigger height; Drives
M569 P1 S0 ; Drive 1 goes backwards
M569 P3 S0 ; Drive 3 goes backwards
M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation
M92 X78.7402 Y78.7402 Z2133.3333 E106.707 ; Set steps per mm
M566 X600 Y600 Z0 E180 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000 Y30000 Z300 E2700 ; Set maximum speeds (mm/min)
M201 X3000 Y3000 Z100 E3000 ; Set accelerations (mm/s^2)
M906 X687 Y687 Z687 E687 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Heaters
M143 S275 ; Set maximum heater temperature to 275C
M305 P0 T100000 B4092 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 0
M305 P1 T100000 B4092 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 X0 Y0 ; Set tool 0 axis offsets
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PMy3dPrinter ; Set machine name
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured
; set my PID values
M307 H1 A319.6 C149.5 D11.9 B0
M307 H0 A138.4 C425.4 D11 B0 -
Finally getting prints, looking like I had the config wrong. Id tried to take the figures used in marlin and translate them to RepRapFirmware. Strange there were no errors as such. Still not got reliable prints yet. But it's not crashing
I am glad you solved it. The only odd thing I can see in your config.g file is the zero jerk speed for the Z axis in the M566 command. I've never tried using a value of zero, so I am wondering whether rounding errors could make the lookahead mechanism keep recalculating to try to meet it. What value are you using now?
Spoke to early, froze again halfway through a 50mm test tower
I'll upload a little later, but starting to think my config errors maybe just disguising a hardware issue. Just not sure how I can be certain. It's only the controller I've changed.
I am inclined to agree. I'm also wondering whether it is time for us to swap your Duet WiFi. However, I would like you to do one more thing. I will shortly release firmware 1.17dev8 and this includes a report of the last software reset code in the M122 report, which previously wasn't working on the Duet WiFi. So please update your firmware to 1.17dev8 later today, do a print, and assuming it fails again, run M122, check that the "Last reset" cause is again software and the reset time corresponds to when the print stopped, and extract the "Last software reset code…" line.
Will do thanks
Heres the current config
M208 X190 Y170 Z180 S0 ; Set axis maxima; Endstops
M558 P1 X0 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds
G31 P500 X0 Y12 Z1.7 ; Set Z probe trigger value, offset and trigger height; Drives
M350 X16 Y16 Z16 E16 I1 ; Configure microstepping without interpolation ab i0-1
M566 X600 Y600 Z30 E20 ; Set maximum instantaneous speed changes (mm/min) ab 8/12 ( Z0 - Z30; E180 - E20)
M203 X15000 Y15000 Z300 E3600 ; Set maximum speeds (mm/min) ab 8/12 (x30000 - 15000 y30000-15000, E2700-3600
M201 X800 Y800 Z15 E1000 ; Set accelerations (mm/s^2) ab 8/12 ( x 3000-800 y 3000-800, z100-15 E3000 - 1000)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent AB 08/12 changed current all form 678 - 800
M305 P1 T100000 B4092 C0 R4700 L0 H0 ; Set thermistor + ADC parameters for heater 1 AB 08/12 B4096-4388
;M301 H0 P10 I0.10 D100 T0.50 S1.0
;M301 H1 P10 I0.10 D100 T0.50 S1.0
M570 S120; Increase to allow extra heating time if needed AB 08/12; Tools
G10 P0 S0 R0 X0 Y0 ; Set tool 0 axis offsets Set initial tool 0 active and standby temperatures to 0C; Network
; set my PID values
;M307 H1 A319.6 C149.5 D11.9 B0 ; Disabled AB 08/12
;M307 H0 A138.4 C425.4 D11 B0 ; Disabled AB 08/12
T0 ; Select first tool -
I have just released the 1.17dev8 build.
Just updated and run a test job. I may have been a little zealous in declaring the last failure. I'm used to the job finishing and parking the print head to one side, where as it doesn't look like the firmware does that for you. So when I came back to my tower, the head was sat at the top, as if it had crashed.. I'm still not getting very good print out put maybe down to configuration rather than faults.
BTW, really appreciate your help.
To park the head when the print finished, add appropriate moving and/or homing commands at the end of your slicer end gcode, just before the M0 at the end. Alternatively, just put M0 in your slicer end gcode and define the shutdown sequence in /sys/stop.g.
Many thanks, I believe my original resetting issues have been resolved. I'm still trying to get a print out of the machine, as my use of the manufacturers Marlin settings, plus a possible extruder issue has caused me some problems. Once i get over this hurdle in the next few days, I will play with my setting to help find the original cause. It does sound like its probably that zero jerk speed for the Z axis in the M566 command.
