Probe center of hole?
I have absolutely NO CNC experience but does this help at all...
https://duet3d.dozuki.com/Wiki/Gcode#Section_M675_Find_center_of_cavity
Yes, it seems to be exactly what I'm looking for. Off to the workshop to test.
M-codes 673, 674 and 675 are not implemented in standard RepRapFirmware. I don't know who added them to the GCodes wiki page.
While we wait for potential support for G38.x this is what is suggested, but I can't say I've tried it for your use:
https://duet3d.dozuki.com/Wiki/Gcode#Section_M585_Probe_Tool
@dc42 said in Probe center of hole?:
@chrishamm and me both have a (very similar) implementation for
M675
. His is in hisv2-chrishamm
branch and I could provide a PRwithin minutesright away. -
@wilriker said in Probe center of hole?:
M675
branch and I could provide a PRwithin minutesright away.Please can you and chrishamm agree on a single implementation.
@dc42 I checked his implementation against mine and the only difference is that mine uses existing helper functions to simplify code and adds some errors for missing parameters. Since we implemented it for the same reason and my implementation is currently used I would say use mine.
EDIT: Here's the Pull Request.
More divergence between the needs of CNC users and FDM users.......
@deckingman Now you're on the hunt...
@rzi Oops, sorry about that. I didn't notice they weren't implemented.
Thanks. Can you do a separate PR for RRF 3 to support using a Z probe as an alternative to an endstop switch, using the same mechanism as M585 in RRF3? See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_M585.
I'll probably provide this either today or early next week.
@dc42 There you go: Pull Request for RRF 3.
@dc42 I totally forgot: an implementation for
M673
can also be found inv2-chrishamm
branch in your repo. But since I don't know what it all comprises besides the code inGCode2.cpp
I can't tell you what to take over. Also it seems he started implementingM674
but it's not finished. -
@gtj0 said in Probe center of hole?:
No problem. An implementation seem not too far away it seems, if I interpret the other posts right. Good thing!
@rzi said in Probe center of hole?:
My pull requests have been accepted today so it will be in 2.03RC4 and also in the next 3.0 build.
2.03RC4 is now released. Thanks @wilriker for the PR.
Damn, you guys are fast as lightning! Thanx
