Controlling a Cetus3D with Duet3D 0.8.5
there is the Meanwell UHP-350-24 in between.
I now migrated to an Duet Maestro to using a absolute silent and not even warm HLG-H320-24A PSU.
While I'm very happy with the basic setup I have problems with those original high impedance motors. The problem is the same as mentioned before: The motors are getting very loud when moving. For me that happens only for fast travels starting with >
F270
movements (G1 Z50 F270 S1
at 256-microsteps and 1359,68 step/mm). Altering the relevant depending values this is regardless of microstepping mode (1-256) and current (200-1400 mA) chosen.With command
G1 Z50 F270 S1
the movent can't be heared at all.
With commandG1 Z50 F273 S1
it is a random mix of loud and absolute silent movements intervals.
With commandG1 Z50 F275 S1
it is a loud all the time.I've attached my config.g to this post: 0_1556283965533_config.g
My motors have something about 30-31 Ohm per phase.
Do you have any idea?
M350 X256 Y256 Z256 E16 I1 do you really need this? this might put quite a high strain on the cpu. 16 with interpolation should be fine in most cases
M203 X1000 Y1000 Z1000 E1000 Thats a very high z speed.
You Probably want to adjust the Hybrid Threshold V for the motors to not go into spreadcycle at higher speeds
see https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing -
@veti said in Controlling a Cetus3D with Duet3D 0.8.5:
Hybrid Threshold V
Was hard to find out what you meant what you meant with Hybrid Threshold V but found the relevant parameter. It is working now – In absolute silence! Thanks a lot for the hints!
I set the threshold to 100 (whatever unit this is) by extending the already in my config existing command
M569 P0 S0
toM569 P0 S0 V100
for all my axes (P0
up toP4
).I not completely understood how this threshold works. Especially I'd like to know why someone would want to switch to Spread Cycle for higher speeds? Higher torque?
@ted said in Controlling a Cetus3D with Duet3D 0.8.5:
if you enter M569 P0 you will see the speed at which the driver switches from stealthchop to spreadcycle.
however at high speed (i think above 60mm/s) the switch can cause layer shifts.to enable spreadcycle all the time use the D2 option
i did the conversion as well with a maestro.it took me a long time to figure out the trick with the V value;-) now i have a question. i set my V values below 100. can this cause a problem? right now im impressed how quiet the printer is!
M569 P0 S0 V70 D3
M569 P1 S1 V70 D3
M569 P2 S1 V120 D3
M569 P3 S1 V120 D3
M350 X64 Y64 Z64 E32 I1
M92 X320.00 Y320.00 Z320.00 E232.00
M566 X1200.00 Y1200.00 Z1200.00 E1200.00
M203 X30000.00 Y30000.00 Z1500.00 E1500.00
M201 X3000.00 Y3000.00 Z500.00 E500.00
M906 X400.00 Y400.00 Z500.00 E500.00 I60@fotomas thanks for this entry it helped a lot!!!
@2rad said in Controlling a Cetus3D with Duet3D 0.8.5:
Yes, also you may get missed steps spurious short-to-ground errors reported. The stealthChop mode doesn't work well at high speeds.
Another cause of noisy motors is running out of motor voltage at high speeds. The motor EMF calculator at reprapfirmware.org will tell you the speed at which you start to suffer loss of torque. The motors will become noisier above that speed too because the driver can't implement microstepping properly.
@fotomas I've successfully tested the Cetus by heating up hot end to 240c and heated bed to 90c to 2 hours .. and it seems stable now.
Now it's time to level the bed and test printing. However, I found that the end stop for Cetus is at the top, so Z = 0 cm is at the highest level and Z = 18+ cm is at the bed level.
So, how did you config the Duet with Cetus flipping Z?
Update 1:
I have changed endstop location to "At High End" and flip z motor direction and the machine can home successfully .. then when I try to move in -Z nothing happened but when I try +Z it keep going up against the end stop! But after that stuttering I can move in -Z about 2.5cm and that's it.Update 2:
I've found the solution by editing "homez.g" in setting:
;G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
to
G92 Z180 ; set Z position to axis maximumThanks,
Cookie -
@cookie
I am using an IR sensor so I have z 0 at bed.
But what you need to do is set that the end stop is at the high end of the axis and in the homing file home to Z 250 mm.The exact commands maybe someone else can help with?
@dc42 said in Controlling a Cetus3D with Duet3D 0.8.5:
what i have found is that with 24v stealthchop2 works ok at high speed.
what does not work at high speed is hybrid mode. Switching from Stealhchop2 to Spreadcycle at higher speeds will cause layer shifts.so i have set my hybrid mode to 200 so that it does not do the switchover and it seems to work.
@cookie said in Controlling a Cetus3D with Duet3D 0.8.5:
Update 2:
to
G92 Z180 ; set Z position to axis maximumIt's better to remove the G92 command completely. Set the M208 upper Z limit to the height at which the endstop switch triggers.
Thanks, I've replaced G92 with M208 in both homeall.g and homez.g already.
I've tried a bit with manual mesh bed compensation using G29.
However, the height is about 18 cm. so I'm not sure I should set the machine Z maximum to 17.5cm or 18.5 cm prior doing mesh bed compensation .. the hot end try to dig the bed if I do 18.5 cm .. So should I set the height a bit shorter to 17.5cm?Would there be any effect if I set the height quite short and compensate like 4-5mm for all point? @dc42 any suggestion about how to do it correctly?
I suggest the following:
- Home the printer.
- Position the nozzle over bed centre.
- Jog the nozzle down until it is just touching the bed. If it won't go low enough, send M564 S0 to remove limits temporarily.
- Send G92 Z0 to define that as Z=0.
- Send G91 G1 H3 Z999 Fxxx where Fxxx is the same feed rate that you use for homing Z. This will stop when the switch is triggered and set the M208 axis limit to the measured position.
- Read off the Z height.
- Use that Z height in your M208 command.
@dc42 Thanks for very clear instruction, I've got it workingNow the next step, I want the heated bed to cool down to 32 Celcius before beginning auto eject macro which I've written for small PLA prints. However, I noticed that M190 is not working under 40 Celcius .. bummer .. not sure why. So how should it be done?
Cookie
Ambient temperature around a printer can be up to 40C under some conditions, so RRF treats temperatures below 40C as cold.
You could wait for temperature to fall to 40.1 then use G4 to wait an additional fixed period .
I designed some parts for my Cetus Duet2 WIFI conversion
https://www.thingiverse.com/thing:4322092
Don’t judge me but I started this about a year ago in the middle of some online configurator tool issues and had to modify the config files the hard way, much easier now.
I choose inductive sensors for homing all the axes. All three of my inductive sensors are stationery requiring Z be homed before Y, however, this keeps the accelerating mass down and the sensor wiring stationary. To interface the inductive sensors output to the Duet I used Schottky diodes. Looking at the numbers I believe the lower forward diode voltage drop meets the worst case Duet input voltage thresholds, regardless it works fine. The diodes are wired so they can only pull down the Duet input pin while the inductive sensor output signal swings from 0.6V to 24V. The homing is done in 2 passes, fast and an extremely slow second pass (F0.1). The resulting trigger position is very repeatable and any faster results in the inductive trigger position having 2 or more nearby but stable values. Could be sensor jitter or CPU capture jitter, anyway it is very repeatable if done extremely slowly.
Cheers
Peter -
After a bunch of tuning I converged on a few variables that might be useful to others.
I choose 256 micro stepping without interpolation. Extrusion steps for the original MK2 extruder mechanism that has a filament release lever is 1650 steps/mm. I also have the warranty replacement MK3 style but the prints were just not as good so I eventually repaired the original.
The steps/mm is the iterative result is from a printing nuts and bolts sliced with prusa. It’s like a micrometer in that it measures the clearance between the printed nut and bolt threads. Measuring thread geometry is a good extrusion test and it quickly reveals temperature, layer height, filament brand, colour etc. all change the steps/mm. https://www.thingiverse.com/thing:3983705
The axis motor currents can be 450ma any lower does not improve the print finish and at 475ma they start making noise.
The extruder motor rotor is shorter and scaling the axis motor current you get a drive current of about 333ma. Any lower does not improve the print finish and higher adds an annoying minor washboard texture to the print surface.
I find that with 0.1mm layers the washboard surface texture increases while it is very hard to see when printing with 0.15 and thicker layers.
My 200W 24V silicone bed heater needed a lower duty cycle and higher PWM frequency to not trip the 120W Cetus AC adapter’s internal short detection circuit. M307 H0 B0 S0.45 F200 it heats to 55C at the same time as the nozzle get to 215C. The upper bed temperature is limited to the 80s and after a long warm up using the stock Cetus power supply.All in all a very satisfying conversion.
-Peter -
Thanks for this information. Very helpful. I have been working on moving my Cetus MK2 to a Duet Maestro as well but running into issues with things like instantaneous speed changes and accelerations etc. What steps did you take to dial these numbers in?
Motor acceleration settings are an accuracy vs vibration trade off and you just pick your poison. The stock Z axis on a Cetus shakes whenever the extruder accelerates. If you add a steel bracket and tie the Z stepper face to the aluminum base it improves dramatically. I upgraded to a 24V power supply and in the config.g below I turn off the steppers when the print finishes. If your Z axis brake/clutch slips fix or increase the stepper idle current so the extruder linear rail does not fall on the print!
The belts have glass cords and they establish the printer motion accuracy together with the steppers so no calibration is even possible aside from axis tramming.; ****** X&Y axis swapped May 6 2020 origin now front left
M83 ; ...but relative extruder moves; Network
M550 P"Duet" ; Set machine name
M552 S1 ; Enable network
M587 S"xxxxx" P"xxxxxxxxxxxx" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P0 S0 ; X Physical drive 0 goes backwards
M569 P1 S1 ; Y Physical drive 1 goes forwards
M569 P2 S1 ; Z Physical drive 2 goes forwards
M569 P3 S1 ; E Physical drive 3 goes forwards
M350 X256 Y256 Z256 E256 I0 ; Configure micro stepping with no interpolation
M92 X1280.00 Y1280.00 Z1280.00 E1650 ; Set steps per mm, extruder calibrated white PLA
M566 X900.00 Y900.00 Z900.00 E120.00 ; set maximum instantaneous speed changes (mm/min), speed threshold for executing next gcode move
M203 X12000.00 Y12000.00 Z12000.00 E7000 ;E1200.00 ; Set maximum speeds (mm/min) about 200mm/s
;M201 X3200.00 Y7000.00 Z3200.00 E12000.00 ; Set accelerations (mm/s^2) for 1Kg,350gr,100gr X skipped a few steps
M201 X1500.00 Y1500.00 Z1500.00 E1000.00 ; Set accelerations(mm/s^2)for 1Kg,350gr,100gr https://wilriker.github.io/maximum-acceleration-calculator/
M906 X450.00 Y450.00 Z450.00 E400.00 I0 ; Set motor currents (mA) and motor idle factor in per cent, Z&Y steppers not quiet at 475ma PSU19.4VM84 S30 ; Set idle timeout
M208 X190 Y191 Z277 S0 ; reversed X&Y axis May6 2020; Endstops
M574 X1 Y1 Z2 S0 ; reversed X&Y axis May6 2020 X low end, Y low end, Z high end, S0 endstop triggered active low Vout; Z-Probe
M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
M557 X15:175 Y15:175 S20 ; define mesh grid; Heaters
M307 H0 B0 S0.66 F400 ; disable heater bed bang-bang mode set max PWM, up Hz, 120W peak with extruder heater Amps jumping around
M305 P0 T50000 B2718 R4700 ; set thermistor + ADC parameters for heater 0 50K bed
M143 H0 S122 ; set temperature limit for heater 0 to 122C
M305 P1 X501 R47000 ; configure PT1000 for heater... per dc42 administrator suggestion with cetus PT100
M143 H1 S285 ; set temperature limit for heater 1 to 285C ....can be 300C; Fans
M106 P0 S0.25 I0 F500 H0 T45 ; set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned on bed
M106 P1 S1 I0 F500 H1 T45 ; set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on extruder; Tools
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
I have designed a smal but effective bracket that supports the Z-axis on the Cetus.
The fit may vary sepending on the version of Cetus and when it was manufactured.But it is pretty easy to draw one, if it does not fit.
