Can't deploy BLTouch clone (3D Touch) Duet 2 Wifi
Can you post a photo of your wiring between the probe and the Duet?
The P0 parameter in the product info needs to be adapted to whichever pin you used on your Duet.
But just to cover the basics, when you power on the printer the probe deploys and retracts a few times, and has a steady red light after?
@bearer The probe deploys and retracts a few times at boot and then has a steady blue light
switch the blue and yellow wire
@veti
I'v switched the yellow and blue wires,
with and without the resistor between blue and black wire as well
still blue led and nothing -
The next question now is if you get a trigger signal from that 3DTouch, I've seen several people having problem's on FB groups the last couple weeks including me
@exerqtor I can get it to deploy and work but some time the probe extends two times and other times it does not trigger when colliding with the bed
Video on imgur -
@oct_opus
Tbh i just think those sensors are next to snakeoil Given how cheap the real probes are, it's not worth the potential headache and anoyance any of the knocnoffs can make. -
Some are hampered by steep fees and taxes when importing stuff, clones are usually declared incorrectly and/or below a duty free limit - I think that makes a bigger difference than $15 clone vs $50 real probe, the latter could easily be closer to $100 by the time it is delivered to me.
But thanks to your comment, I checked out their site and found their Ali Express store had a sale, $35 shipped, below the free import limit - yay!.
