Grid bed compensation
Sniffle, thanks for your report. Reporting bugs here is best. Were you entering the commands on PanelDue, the web interface, or via a USB host when you got those checksum errors?
Alex, I had forgotten that there are probes that need to be deployed. I could make it call deployprobe.g and retractprobe.g at the start and end of G29 S0. But I am now wondering if there is any point, since the bed compensation runs G32 and you can do the deploy and retract in there.
David
Is that to say that running a G29 will run the Auto Cal on a delta First before doing the grib Comp.?
I was just going to add G29 at the end of my Start Script in s3d but if I can just replace the G32 with G29 it will be easier
Doug
When I tested it yesterday running G29 just does the grid levelling.
If you put G29 into your bed.g after autocal then it will do both when you run the file from start gcode with G32. -
David: it depends on how you rate the new feature.
IMHO G29 is an improved version of G32. Though G32 is not a real feature, at least in RRF. G32 just executes the bed.g script which is just a execution of multiple G30 commands. So G30 with the plane calculation is the real feature.
So what if we declare G32 is bed compensation and G30 and G29 are just two different methods to compensate.
That way we can use bed.g and it depends on what's in it which compensation is done.On the other hand if you see G29 a replacement of G32 or an alternative then you should allow probe management for G29 too with special macros.
I vote for what I wrote first… I admit I had problems understanding it myself at first, that's why I wrote all the posts above. But now I thought about it and I think using G32 as a general bed compensation command is WTG...
+1 for Alex's approach. Keeping bed.g as theeditable single point for defining what happens makes the most sense.
For this nothing has to be changed, it is just a definition. But the documentation should probably be updated to emphasize this…
David, those errors were reported on the PanelDue, they did not occur or at least not reported on the web interface.
As to the above discussion of using bed.g as the single point of reference for enacting whichever compensation you want i definitely agree, but whats the difference between the spiral 5 point compensation and G29… I was expecting G29 to be an automated version of the later.
Is G30/3G32 Planar and G29 mesh? I'm sure its just a matter of terminology crossing my understanding wires.
What I meant was: did you enter the M557 and G29 commands on the PanelDue keyboard, or by some other means?
The 5 point compensation requires you to set up a bed.g file (or set up the points using M557). It works on Cartesian and CoreXY printers only. You have the option of including trigger height corrections for each probe point, although it's unlikely that you would need to do that on a Cartesian or CoreXY printer.
The new grid compensation can probe a much larger number of points (currently 121 on the wired duet and 441 on the Duet WiFi). You define the area to be probed and it works out the probe points. It can be used on delta printers too. You can't enter trigger height corrections.
I found a little issue with the Z offset and dive height. It seems both are connected somehow when probing.
IMHO this is not ideal.
Let me describe it a bit…Lets assume we have a probe which triggers when the nozzle is 2 above the bed. So with a Z offset of 0 and a dive height of 3 when probing the bed moves to Z=3 and the probes and so on.
If you already adjusted your offset to 2 so that the nozzle touches the bed then the bed just dives by 1. I think that's because the dive is calculated from Z0 which I changed by setting the offset.
So if I have to change my offset every now and then I also have to adjust the dive height and add the offset to the desired dive height.I stumbled over this issue again because of playing with the BLTouch.
The problem here is that if the nozzle touches the bed the BLTouch is not able to trigger because it is already triggered. So if I start with a Z offset of 0 and a dive height of 2.5 then all is fine, probing is fast because the bed is just about 1 away from the trigger pin.
But when I now adjust the offset so that my nozzle touches the bed and the BLTouch lowers the pin it already hits the plate and is triggered resulting in alarm state which will break the probing sequence.IMHO the offset should not influence the dive height, the dive height should always be calculated from the trigger point of the probe and not from the Z0 location.
I wonder how long a probing sequence will last if you max that…
I won't try until I am not able to load the result back in -
David, being able to probe 441 points is one thing, I have not dug into your grid compensation code but does having that number of (different) points in the grid have an effect on the gcode->step generation speed? Does that limit the step rate or once the curve is fitted then the process required is the same?
It won't have any significant effect. The reason I chose 441 is so that you can probe a 400x400 bed with a grid spacing of 20mm.
The M557 command I endtered through the web interface, and then I moved to the paneldue keyboard to initiate the G29 command because I had interference concerns and wanted to witness the first row so I could make a proper adjustment should it be needed.
I am using the H offset in auto calibration, does grid levelling in the current state help to improve it?
No. If you need values of the H parameter that are greater than the residual height errors, then grid compensation will probably make things worse.
The autocalibration takes account of the H offsets in bed.g but the grid bed compensation doesn't.
Ah yes, i found out the hard way on this one. everything is set "longer" so i know the probe will make the bed, the everything offsets "shorter"
so getting everything just right was a bit of a trick for me, i think i got it but ran out of time last night. will try again tonight BUT,
can some one please point out the differences between theses H values from these codes. i think I'm still a bit unclear even after a lot of reading. im not sure why but i would be grateful for some one to clear this up for me.
M558 P1 X0 Y0 Z16 H3 F100 T10000
what is the Z value here?
G31 X0 Y0 Z20 P500
This Z value is the off set, so if i put G31 Z20 this means that when the probe is triggered it thinks the hot end is 20mm from where it was triggered right?
so why don't we use the probe off set for X,Y ? how dose it know where the probe is VS the hot end? for bed compensation this would be needed right?
Thanks in advance and Thanks for bed compensation!!!! its needed me thinks even with a .140 deviation. i think i need more
( I've been cutting PCB's with .1mm depth)
~Russ Gries
In the M558 command, Z16 is the same as Z1 and means that the Z probe is used for Z homing. H3 is the dive height, which means that when you use G30 with defined XY coordinates to probe the bed (and also G29 in the 1.17 dev build), probing starts 3mm + the probe trigger height above where the bed is expected to be.
In the G31 command, the Z parameter defines the trigger height of the Z probe.
The documentation for how gcodes behave in RRF is the reprap.org wiki at http://reprap.org/wiki/G-code. Let me know if you think particular parts need to be clarified.
HTH David
These are my results bit concerned by one reading noticed whilst it was probing that the LED on the IR Board lit but it kept on moving down (did this just once towards the end of the third row)
David would appreciate it if you could cast you eyes over this and give any advice that you may have.
RepRapFirmware height map file v1
xmin,xmax,ymin,ymax,radius,spacing,xnum,ynum
-140.00,140.10,-140.00,140.10,150.00,20.00,15,15
0,0,0,0,0,-0.123,-0.137,-0.189,-0.191,-0.205,0,0,0,0,0
0,0,0,-0.051,-0.052,-0.086,-0.113,-0.152,-0.211,-0.237,-0.263,-0.285,0,0,0
0,0,0.053,0.026,-0.016,-0.051,-0.051,-0.123,-0.175,-0.203,-0.254,-0.264,-3.224,0,0
0,0.140,0.072,0.038,0.001,-0.061,-0.051,-0.039,-0.174,-0.252,-0.265,-0.235,-0.237,-0.318,0
0,0.177,0.129,0.086,0.112,-0.089,-0.062,-0.128,-0.148,-0.213,-0.202,-0.202,-0.286,-0.288,0
0.304,0.226,0.178,0.123,0.124,0.042,-0.087,-0.422,-0.153,-0.212,-0.180,-0.223,-0.213,-0.347,-0.332
0.308,0.249,0.366,0.125,0.174,0.077,-0.073,0.174,-0.091,-0.128,-0.087,-0.161,-0.172,-0.203,-0.173
0.360,0.313,0.303,0.186,0.190,0.101,0.004,0.158,-0.071,-0.111,-0.148,-0.190,-0.175,-0.154,-0.225
0.338,0.299,0.250,0.213,0.173,0.139,0.063,0.162,0.012,-0.074,-0.125,-0.185,-0.161,-0.163,-0.187
0.400,0.375,0.296,0.274,0.236,0.197,0.110,-0.001,0.026,-0.062,-0.075,-0.124,-0.142,-0.113,-0.115
0,0.234,0.180,0.214,0.216,0.191,0.127,0.086,0.061,0.005,-0.025,-0.024,-0.071,-0.061,0
0,0.438,0.389,0.312,0.313,0.236,0.125,0.127,0.102,0.061,0.000,-0.121,-0.050,-0.040,0
0,0,0.371,0.300,0.264,0.211,0.215,0.237,0.127,0.121,0.102,-0.046,-0.026,0,0
0,0,0,0.387,0.324,0.339,0.226,0.226,0.150,0.153,0.100,0.049,0,0,0
0,0,0,0,0,0.302,0.275,0.229,0.175,0.114,0,0,0,0,0Looking at the figures it would suggest that the bed is not flat however it is 6mm thick Ecocast Tooling plate with Printbite on it Think I will have to get a straight edge on it and check it?
Doug
PS not always repeatable run again I gat the following
0,0,0,0,0,-0.139,-0.188,-0.139,-0.202,-0.224,0,0,0,0,0
0,0,0,-0.058,-0.066,-0.109,-0.141,-0.129,-0.186,-0.198,-0.191,-0.176,0,0,0
0,0,0.013,-0.008,-0.053,-0.071,-0.087,-0.113,-0.162,-0.190,-0.199,-0.267,-0.237,0,0
0,0.124,0.076,0.025,-0.026,-0.054,-0.078,-0.137,-0.127,-0.165,-0.201,-0.189,-0.227,-0.226,0
0,0.198,0.120,0.047,0.089,-0.074,-0.097,-0.153,-0.188,-0.477,-0.190,-0.199,-0.237,-0.211,0
0.312,0.229,0.198,0.098,0.097,0.004,-0.089,-0.516,-0.150,-0.209,-0.197,-0.183,-0.216,-0.296,-0.250
0.287,0.263,0.292,0.100,0.190,0.015,-0.102,-0.039,-0.125,-0.149,-0.137,-0.198,-0.188,-0.220,-0.192
0.378,0.289,0.328,0.172,0.133,0.078,-0.086,0.134,-0.100,-0.150,-0.176,-0.234,-0.187,-0.199,-0.221
0.360,0.291,0.260,0.185,0.111,0.108,0.024,0.073,-0.024,-0.116,-0.187,-0.252,-0.201,-0.215,-0.187
0.447,0.397,0.336,0.276,0.180,0.164,0.073,-0.050,-0.049,-0.109,-0.151,-0.172,-0.211,-0.175,-0.161
0,0.337,0.289,0.227,0.179,0.127,0.086,0.034,-0.039,-0.060,-0.113,-0.108,-0.171,-0.153,0
0,0.478,0.397,0.374,0.270,0.141,0.085,0.074,0.037,-0.048,-0.080,-0.187,-0.126,-0.175,0
0,0,0.373,0.364,0.265,0.161,0.139,0.212,0.040,0.046,-0.008,-0.149,-0.115,0,0
0,0,0,0.346,0.295,0.273,0.148,0.136,0.084,0.024,-0.055,-0.078,0,0,0
0,0,0,0,0,0.240,0.178,0.084,0.090,0.004,0,0,0,0,0Which to my untrained Eye looks much better Think I may have a wiring Crosstalk Issue to be honest Need to maybe re-wire the Hot End area using Screened Cable?
Doug, I think you may have a bad connection between the IR sensor output and the Duet. I can't think why else the head would continue to move down after the LED has lit. I have a long unshielded cable between the hot end and the Duet too and it doesn't cause me any problems.
Thats what I am starting to think Myself (and with the PT100 as Well) will get some Shielded cable tomorrow and re-do those connections (If I have to re-do them I may as well use Shielded stuff)
Doug
