Duex5 Testers
I guess all at T3P3 must be thinking that no news is good news but in case not, I just thought I'd report in to say that all is well with my shiny new Duex5. It's only running a third extruder, a fan and some LED lights at the moment but no probs at all. I added a couple of pics to my case design on Thingiverse that shows it fitted and wired up next the Duet WiFi http://www.thingiverse.com/thing:1859048.
Many thanks. Great product, great service as always.
Thanks Ian!
Being in the US it is probably taking longer to arrive. But I have a new delta printer with a Pyramid 3-in 1-out mixing hot end ready to go with the new expanded drivers.
I've not heard of the Pyramid hot end and a quick Google search didn't turn up anything. Is it anything like the Diamond 3 in 1 out that I'm using?
Was the ribbon cable long enough?
The one I ordered was. :). Given that the board is designed to go back to back with the Duet, I guessed that the "standard" ribbon cable might be a bit short because it has to have a twist and the connectors are no longer opposite each other. I don't know for sure if the "standard" cable would be too short as I asked for a 300mm long cable when I ordered the Duex5 (the additional cost was very reasonable I might add). I can say that 300mm is a bit too long - I'd guess 200mm or maybe a bit shorter still might be OK.
Oh dear, the one that came will be to short then!
Tony - What parts do i need to build one? Can i source them from RS ?
I use as similar side-by-side configuration in my bench test setup. A 180mm cable is just about long enough.
Yes you can get the parts from RS, Farnell, Rapid etc. The ribbon cable is standard 0.127mm pitch 28awg 50 way and the connectors are standard 2x25 way 2.54mm pitch IDC sockets.
Thanks
Quick Question. How do i get for example FAN3 to stay on permanently?
Ok scrap that. Worked it out!
Works a treat deckingman
thanks!
That's neat. I didn't manage to lose all the ribbon cable in my installation - I took a guess at 300mm which was way to long. What length did you end with?
Edit. I think it might work better still with a bit more separation between the boards - there is room to move the Duex5 but still keep the outside the same. I might tweak the design at some point.
I'll let you know how long it is in the morning after the print finishes.
Is it still possible to get one of these or do we have to wait for production boards now? If the latter, what is the timing? I have 3 x Z steppers with external drivers ATM I need to drive and was going to make my own breakout board but one of these would be much easier.
