Extruder motors not moving
Thanks for the fast replies, guys, but the problem remains :I
What might be wrong with my tool0? I am still "attempting to extrude with no tool selected" and the M563 P0 returns "Attempt to print details of nonexisting tool".
The firmware was the newest about a month ago.
Here the config.g with the corrections:
M550 PXTP1
M111 S0 ; Debugging off
G21 ; Work in millimetres
M555 P2 ; Set firmware compatibility to look like Marlin
;M208 X0 Y0 Z0 S1 ; Set axis minima
;M208 X549.5 Y800 Z800 S0 ; Set axis maxima; Endstops
M574 X1 S1 ; Define active high microswitches
M574 Y1 S0
M574 Z1 S0M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
M350 X16 Y8 Z16 E16:16 I0 ; Configure microstepping without interpolation
M92 X641 Y641 Z641 E600:600; STEPS PER MM
M584 E3:4
M566 X1 Y1 Z1 E1:1 ; Set maximum instantaneous speed changes (mm/min) “JERK”
M203 X4000 Y175000 Z1500 E1000:1000 ; Set maximum speeds (mm/min) SPEED
M201 X120 Y120 Z120 E120:120 ; Set accelerations (mm/s^2) “ACCELERATION”
M906 X2000 Y1700 Z2000 E1700:1700 I30 ; Set motor currents (mA) and motor idle factor in per centM84 S1 ; Set idle timeout
;heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor for heater 1
M305 P2 T100000 B4138 C0 R4700 ; Set thermistor for heater 2; Tools
M563 P0 D3:4 H1:2; Define tool 0
M302 P1;M563 P0 D3:4 ; Define tool 0 (no heaters assigned)
;M567 P0 E1:1
;M584 E3:4
;M302 P1 ;COLD EXTRUSION ON; Network
M550 PXTP1 ; Set machine name
M540 PBE:EF:DE:AD:FE:ED ; Set MAC address
M552 P0.0.0.0 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S1 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P2 S1 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned offI'm clueless!!
@propellerhat The message " attempting to extrude with no tool selected" means exactly that. You have only one tool defined so simply enter the command "T0" before you attempt to extrude. Better still, just put T0 at the end of your config.g file.
Sorry for not saying so but I have typed "T0" in the console the first thing :I Despite it there is no tool selected, and the "Attempt to print details of nonexisting tool" looks a lot like the T0 is not even defined... even though there it is. I have also put the T0 in the config.g without any change in the situation.
@propellerhat Ahh, yes think I see the problem.
For your tool definition you have M563 P0 D3:4 H1:2.
It's a bit confusing and an easy mistake to make but the "D" parameter in that command refers to the extruder number, not the drive number. So in your drive mapping M584 E3:4 means that the first extruder uses drive 3 and the second one uses drive 4. Thereafter, you have to refer to extruders, not drives. The first extruder is extruder number 0 and the second is extruder number 1 so your tool definition should be M563 P0 D0:1 H1:2.
Edit. The error message is a tad ambiguous because it should really say "Attempting to extrude with a tool that has non-existant extruders".
All right! Now E1 motor runs. That was a silly mistake as I have successfully configured a printer with 6 extruders a couple of years ago. The E2 motor still stays unpowered though, any idea what might be causing that?
Is it possible to command E1 and E2 separately without changing tools? Maybe I can change the "E" into other letters..?
My goal is to have 5 independent axis, no heaters needed. -
@propellerhat Er, you don't have an E2. You have extruder 0 and extruder1.
But assuming that's just a typo on your part, and thinking about it some more, you might need to use M567 to define the mixing ratio for the two extruders. How are the extruders configured? Is it a 2 in 1 out hot end or have you got them set up as a push-pull configuration. Either way, I think you'll still have to set up the mixing ratio using M567. If it's a 2 in 1 out then the ratios for each extruder ought to add up to 1.00. If they are push-pull, then the ratio ought to be 1.00 for each extruder. Once that's done, then DWC will allow you to extrude by individual drives or by mixing.
@propellerhat said in Extruder motors not moving:
.............................My goal is to have 5 independent axis, no heaters needed.
I've just noticed this comment that you made. You haven't said anything about the application that you are working on but have you considered creating additional axes such as U and V, rather than re-purposing extruders?
I think you mean E0 and E1, as Ian said. Your tool 0 is configured to use both. So with tool 0 selected you can do this:
G1 E10:0 F120 ; extrude 10mm from the first extruder
G1 E0:10 F120 ; extrude 10mm from the second extruder
G1 E10:10 F120 ; extrude 10mm from both extrudersAlso see Ian's point about creating additional axes instead.
@dc42 That's useful to know. I hadn't considered the possibility of being able to use multiple E values separated by colons.
Awesome. After adding the 1:1 mixing ratio both motors turn.
Great possibility that G1 E10:0/E0:10 to control which motor turns, allthough it might come more handy later to create those extra axes.
Now it looks all set up to get stuck with some other kind of problems than the configuring
Thanks!
