Endstops on Duex5
Hello
I have a little question moreIf I want to set the endstops x-min y-min z-max on the duex5, do I have to specify which code in the conig?
I always have the lasers in place and not the axes endstops.
greetz
Michel -
Remapping endstops is only supported in the 2.03beta firmware. See the C parameter in the M574 command, https://duet3d.dozuki.com/Wiki/Gcode?revisionid=HEAD#Section_M574_Set_endstop_configuration
Yes I have
However, my question is how do I write the M574 correctly so that this is possible?
; Endstops M574 C5: X1 C6: Y1 C8: Z1 S1
Is it that right?
regards
No, you need a separate M574 command for each endstop when you use the C parameter.
then it is so right
M574 C5:X1 S0 ; Set active high endstops
M574 C6:Y1 S0 ; Set active high endstops
M574 C8:Z1 S0 -
@3dware said in Endstops on Duex5:
M574 C8:Z1 S0You need:
M574 C5 X1 S0 ; Set active high endstops
M574 C6 Y1 S0 ; Set active high endstops
M574 C8 Z1 S0The order of the parameters in a command doesn't matter.
I have the NC switch on E-StopV and Z Stop.
This endstop is XEND for me
I have the problem that the switch has no influence and the axis always stays where it is and sets zero.
many thanks for the help
You can use the Machine Properties page of DWC 1.22.6, or the M119 command, to read the endstop switches in order to test them.
