Master- Slave Approach in DUET-2
The expansion board has an ATSAME51 processor, which has a 120MHz ARM Cortex M4F core.
@dc42 Do you think the duet2 can be tweaked to fit in a master slave using SPI/ UART with another board??
@georgep said in Master- Slave Approach in DUET-2:
The technical difficulties would be substantial, also I suspect that the master would need more RAM than the processor on the Duet has, unless we removed some major feature to free up RAM.
You can already drive 12 stepper motors independently using a Duet + DueX5 + 2 external drivers. Another user already did a firmware patch to support another 2 external drivers, giving 14 in total.
WoW... 2 more external drivers! where do we connect the 2 external drivers? if the Duet2 is connected to the duex5. Where are the additional pins for more drivers? Do we connect it in the display pins?
See the references to CONN_LCD at https://duet3d.dozuki.com/Wiki/Using_external_stepper_motor_drivers.
Really cool.
12 stepper drivers sounds good to me.
It is a good start.Cant wait to start my project. Will come back with more queries as I progress.
Thank You
Eager to see the Duet 3 in action too. Is there any way to get my hands on a prototype?
I would love to contribute in some way too.
Prototypes are very expensive to make because the PCB production and especially the assembly costs are very high for small numbers of boards. So we have only a few Duet 3 prototypes. We've not yet decided whether we will make pre-production boards as we did for Duet WiFi, or go straight to production.
Well i am sure it will be worth the wait... 8 Expansion boards is like a dream come true. You guys have taken expansion to a whole new level .
