Controlling a Cetus3D with Duet3D 0.8.5
Thanks a lot, that's beyond useful.
- Cetus MK3 already has 3x homing switches, so sounds like I might even already have all I need.
- Adapters seems the right way to go so it's easily reversible, but eh, 'ain't gonna need it '.
- Duet 2 Wifi came with a little bag of JST connectors; if I'm lucky, the metal crimp terminals might be the same. If so I'll just need to change the plastic shells over (while carefully counting on my fingers which colour goes to which pin). If I'm extra lucky and Cetus doesn't change their wiring too often, maybe it'll even match your photos and help confirm I'm on the right track
Big thanks again for that, I'll try to post something once I get things going
@dsmudger I just got my MK3 running and the Duet Wifi is laying around. Seem like I’ve to figure out the right crimping tools or learn how to crimp without them. I’m so novice when come to wiring works. Will keep you update when there is progress.
Thanks
re adapter: https://www.thingiverse.com/thing:3465278 is what i did for what may be the same "problem"
And JST XH terminals which Tiertime use aren't compatible with the molex picoblade, you will need to replace terminals, or as I did, buy male JST XH and make adapters just to make it reversible.
@fotomas said in Controlling a Cetus3D with Duet3D 0.8.5:
On the hotend it self I made a new board using experimental circuit board and matching connectors.
Hello, @fotomas
I'm working on MK3. The X,Y,Z motors and endstops are working as it should now. But when come to 16 pin connector wiring to hotend's motor, heater, thermistor and fan .. how you figured out which is which?
Thanks,
Cookie -
Dear @cookie
That is quite easy.
Just measure the connections between the Control board end and the daughter board that has separate connections for each "thing". Thermistor, stepper motor, fan, heater. If I remember correctly the hearer uses double wires for both + and -, most likely to increase the cable area.
They used the same layout on my Up Mini 2. Doubling the heater wires to increase current carrying capability of both wires and connectors. From your picture they use the same pinout as well.
@fotomas thanks!
I spend a few hours figured out, I’m a novice when come to electronic. I tried mapping out the circuit board and use thermistor to check each pair connectivity, then could identified them all
Then, Cetus use PT100 as thermistor. Did you swap out to something else or buy PT100 daugther board?
Also, you get new heater or not? And did you splice the wire for double heating pin, right? Still not sure how to do it right ..
I'm using the original cetus thermistor. It works well after finding the correct values for it.
I do not think a negative B value is common.
M305 P1 R4700 T112 B-425 C7.060000e-8 -
M305 P1 R4700 T112 B-425 C7.060000e-8Looks like you are using a PT100 but you have connected it directly to the thermistor input. This will give you a very poor resolution and you should use the PT100 daughter board instead. However, if you want to use a direct connection then I suggest this:
M305 P1 X501 R47000
This says you are using a PT1000 sensor, but inflates the series resistor value by a factor of 10 to compensate for the fact that you are actually using a PT100.
Hi guys great thread!
I have a couple of questions -
Why do you think they shipped the cetus with 38 ohm steppers? Is there some reason to use high resistance motors?
Is there any advantage to the mark 3 if you're just going to rip out the electronics?
Thanks
Hello
I'm also replacing the main board of my Cetus MK1 with a Duet Maestro.I'd like to run both the mainboard and the original heatbed with the original 19V PSU that came with the Cetus. The original main board did limit the current or voltage of the heatbed somehow to not overburden the small PSU. It is that way limited to around 60 °C. For 100 °C it has a connector for an external PSU with more power. As I'm fine with that temperature I want to ask you if it is possible with the Maestro to limit the current or voltage for the heatbed as well? I don't want to destroy my PSU or risk the print to fail due to an underpowered Maestro where the current is sucked away by the heated bed.
If it is not possible, what PSU dimension do you recommend for the Cetus? I wonder if the MeanWell HLG-320H-24A is big enough, even for 100°C later on?
@ted said in Controlling a Cetus3D with Duet3D 0.8.5:
It is only possible to limit the average power, by means of controlling the maximum duty cycle of the PWM signal for the bed.
https://duet3d.dozuki.com/Wiki/Gcode#Section_M303_Run_heater_tuning
https://duet3d.dozuki.com/Wiki/Gcode#Section_M307_Set_or_report_heating_process_parametersP parameter in M303 and S paramterer in M307
if you get an external mosfet for the hotbed its easy to use 2 power supplies. You can even use different voltages that way.
Thanks for the fast answers! I then will buy a new PSU. I go for a one PSU for everything solution.
Are 320 Watts of the HLG-H320-24A enough for that small heatbed and then 100°C? Next would be 480 Watts and much more expensive. I prefer the HLG series as it works with passive cooling.
there is the Meanwell UHP-350-24 in between.
I now migrated to an Duet Maestro to using a absolute silent and not even warm HLG-H320-24A PSU.
While I'm very happy with the basic setup I have problems with those original high impedance motors. The problem is the same as mentioned before: The motors are getting very loud when moving. For me that happens only for fast travels starting with >
F270
movements (G1 Z50 F270 S1
at 256-microsteps and 1359,68 step/mm). Altering the relevant depending values this is regardless of microstepping mode (1-256) and current (200-1400 mA) chosen.With command
G1 Z50 F270 S1
the movent can't be heared at all.
With commandG1 Z50 F273 S1
it is a random mix of loud and absolute silent movements intervals.
With commandG1 Z50 F275 S1
it is a loud all the time.I've attached my config.g to this post: 0_1556283965533_config.g
My motors have something about 30-31 Ohm per phase.
Do you have any idea?
M350 X256 Y256 Z256 E16 I1 do you really need this? this might put quite a high strain on the cpu. 16 with interpolation should be fine in most cases
M203 X1000 Y1000 Z1000 E1000 Thats a very high z speed.
You Probably want to adjust the Hybrid Threshold V for the motors to not go into spreadcycle at higher speeds
see https://duet3d.dozuki.com/Wiki/Gcode#Section_M569_Set_motor_driver_direction_enable_polarity_and_step_pulse_timing -
@veti said in Controlling a Cetus3D with Duet3D 0.8.5:
Hybrid Threshold V
Was hard to find out what you meant what you meant with Hybrid Threshold V but found the relevant parameter. It is working now – In absolute silence! Thanks a lot for the hints!
I set the threshold to 100 (whatever unit this is) by extending the already in my config existing command
M569 P0 S0
toM569 P0 S0 V100
for all my axes (P0
up toP4
).I not completely understood how this threshold works. Especially I'd like to know why someone would want to switch to Spread Cycle for higher speeds? Higher torque?
if you enter M569 P0 you will see the speed at which the driver switches from stealthchop to spreadcycle.
however at high speed (i think above 60mm/s) the switch can cause layer shifts.to enable spreadcycle all the time use the D2 option
i did the conversion as well with a maestro.it took me a long time to figure out the trick with the V value;-) now i have a question. i set my V values below 100. can this cause a problem? right now im impressed how quiet the printer is!
M569 P0 S0 V70 D3
M569 P1 S1 V70 D3
M569 P2 S1 V120 D3
M569 P3 S1 V120 D3
M350 X64 Y64 Z64 E32 I1
M92 X320.00 Y320.00 Z320.00 E232.00
M566 X1200.00 Y1200.00 Z1200.00 E1200.00
M203 X30000.00 Y30000.00 Z1500.00 E1500.00
M201 X3000.00 Y3000.00 Z500.00 E500.00
M906 X400.00 Y400.00 Z500.00 E500.00 I60@fotomas thanks for this entry it helped a lot!!!
