Solved PanelDue No Responding with Duet3D WiFi
Hallo,
my PanelDue 7" V3 are do not Respond or Connetcted with the Duet3D WiFi Board.
I cann´t see the Duet3D Config on the Screen (i have 2 Extruder but i can see only one) and i have no Temp. of the Connetced Items on the Display
If i write G Codes over the PanelDue Screen but the Duet3D Board nocht Responds (no Reaktion).I have the PanelDue Connected over the 4pin cable
and i have try over the expansion port on the Duet3D board.PanelDue-v3-7.0-nologo.bin Firmware on PanelDue
Release 2.03beta2 Firmware on Duet3DHow i can fix this issue
The connections in your second photo look correct to me. Are the PanelDue and the Duet both set to the same baud rate? The default is 57600. For PanelDue it is selected on the Setup page. On the Duet it is set in the M575 command in config.g.
THX, the Boudrate was wrong adjusted
now it´s works perfekt
