Duet Web Control 2.0.0-RC6
what had happened to language files / localization ?
unchecking ToolFan in "change visibility" shows error $t('panel.fans.noFans') }}
@chrishamm
DWC2 RC6, MacOS, Chrome 72.0.3626.121Is there any way to adjust the size of the navigation panel on the left side of DWC2? I know I can completely remove it, but I'd rather just make it smaller (so it takes up less horizontal space.) The reason for asking is that when the navigation panel is exposed (which I prefer), the rest of the browser page looks poorly squeezed into the available space. Here's an example from my (very old) MBP:
Notice that the temperatures numbers (middle box) are all truncated and the the temperature graph looks very thin. (Also, what's going on with the temp graph legend for MCU? It doesn't look like a dashed line at all... The first time I saw it, I thought my son had attacked my screen with a magic marker.)
Thank you
Gary -
the macro continues to load and nothing can be seen
@NicoLab28 @c310 Thanks, I'll fix both in the next version.
@c310 Localization support has been implemented but I haven't added any translations yet. If you wish to contribute, feel free to translate this file https://github.com/chrishamm/DuetWebControl/blob/next/src/i18n/en.js and send it over to me. We still need to find a solution for keeping them up-to-date though - perhaps a mailing list would be good.
@garyd9 You can hide the navigation menu by clicking on the button in the top left corner. That is supposed to happen automatically when the screen width becomes too low. Can you tell me what resolution you use on your MBP?
@gideon That's quite odd. Do you have a lot of files in your macros directory?
@chrishamm said in Duet Web Control 2.0.0-RC6:
i can do Russian, but belive @Monderlog have done that.
perhaps you can publish ru.js on github and we will review that -
@chrishamm probably trivial but : how can I 'pin' the fan speed in DWC 2?
@chrishamm i have 10 macro's
@chrishamm
small bug:
I added a chamber heater with some fans on it.
This fan is created with that commands:M307 H3 A-1 C-1 D-1 M106 P3 S0 I0 F100 H-1 B0.5 C"Chamber" A3 L0.23; Heated chamber fan
And it doesn't show up when I select it in visibility
This is great! I was considering forking and doing a more modern UI.
Will test and write back with any issues
1440x900. (It's an older MBP.)
Take care
Gary -
I commented on an earlier release of DWC, I believe RC4 or 5? Anyway, my issue was that the height map was storing correcting and applying software correction to my print, but the image of the height map would not display.
It turns out this was due to the browser I was using! Apparently Brave (a browser based on chromium that natively blocks ads/popups/trackers) does not allow for that image to refresh or display for some reason. When I pulled up DWC with Firefox it displayed perfectly fine.
A minor note - is the Fan RPM reading gone for good? There seems to be no way to either toggle or display it in DWC 2.
@mike I miss that as well. Jumped through all the hoops to read it out and no it's no longer displayed - I would very happily treat it for the Z probe value since I do not even have a Z probe.
Feature request / idea: temperature of heater in degrees or percent o taget temp in the title/heading.
So when a print is started I can se the progress of heating up, then when the printing starts it switches to print progress as of today.
Great new GUI, keep up the good work!
mponents (also fixes a bug that caused all inputs to stop working once the heightmap was activated)
Changed click behaviour of file list items to be activated on a single click again
Added touch events to event+file lists to show the context menu on devices that do not support the native JS contextmenu event
Print information is no longer cleared when a print finishes
Simplified file list reset when the connection is interrupted
Print+Simulate options are hidden when a job file is being processed
Escape closes the text editor again
Height map is automatically reloaded once 'heightmap.csv' shows up in a G-code response
Minor other changes
Bug fix: Notification when editing a large file was not displayed during download
Bug fix: Macro list did not return to the root directory when the connection was interrupted
Bug fix: Warm-up time was not displayed
Bug fix: Selected tool was no longer highlighted when the light theme was selected
Bug fix: Drag&Drop was completely broken in Chrome and the drag animation stopped working anywhereFor me drag and drop in chrome is still not working. It always shows me the opended gcode
Agreed - in Chrome or Safari on my Mac, drag and drop to drag files from my desktop to the GCode files directory does not work.
@smoki3 said in Duet Web Control 2.0.0-RC6:
@johnocfii yes I am only on mac.
@chrishamm I also noticed that I can not move the cursor my the arrow keys in the editor
I looked everywhere but can't find Machine Properties to endstops ecc.
Also is it possible to make the webcam image fill the space?
In DWC2 the cam image takes much longer to loads than the old interface.Thanks
