Why am I having to run with an extrusion multiplier of 60%?
If you are worried about your extruder skipping steps then drop your max speed to see if that makes a difference.
My original point that you are suffering from overextrusion not underextrusion, therefore skipped steps are not causing your original issue.
Hi Tony,
No skipped steps with the Titans - the point was that maybe lesser extruders might skip steps and so "mask" the problem.
No skipped steps that is until I get to the point where the Diamond hot end can't melt the filament fast enough. In other tests, I've determined this to be around 120mm/sec for PLA at 195 degC - much faster than I would normally print. Still no skipped steps but it does chew the filament.
If I print at what I consider to be fast (around 60mm/sec) then that problem infill situation will be printed running the extruder as if the print speed was 90. The Diamond/Titan combination can handle that without skipping steps or stripping filament but could lesser extruders? Probably yes but maybe not always?
THIRD EDIT. Looking at the gcode file, as near as I can make out, this thin infill is achieved not by zig zag moves but by simply upping the extruder speed by 50%. Maybe this is the problem? Maybe a lot of extruders will skip steps so the print will look fine but the Titans don't? So maybe it only affect those with the slic3r/Titan combination?
As I understand it, this is precisely the "gap fill" situation in which slic3r 1.2.9 has a bug. Is it possible for you to test these same parts with a different version of slic3r? I have not had any success compiling the development version of slic3r, but you might be able to find the previous version pre-compiled somewhere.
Also as I understand it, slic3r is trying to fill the gap exactly by extruding extra to make a really wide line of plastic, and the bug is a miscalculation of how much extra it needs to extrude.
I've been using the latest development versions of Slic3r with great success both on a Windows and Linux. Their build environment instructions are pretty spot on, what issues have you had?
I believe this is the guide I followed: https://github.com/alexrj/Slic3r/wiki/Running-Slic3r-from-git-on-Windows
I'm trying to compile and run it on Linux. I followed these instructions: https://github.com/alexrj/Slic3r/wiki/Running-Slic3r-from-git-on-GNU-Linux and wound up with something that just segfaulted. It's out of master, so it's possible I just picked a broken version.
It is possible that gap fill is not properly calculated. However, this should not affect the whole layer, unless the layer entirely consists of walls with odd thickness.
Latest update. I'm getting very similar results using S3D. That is to say, I get all the issues that suggest over extrusion using an "Extrusion Multiplier" of 1.00 but almost perfect results when I set it down to 0.80. So it has to be my machine but at this moment in time, I'm still stumped.
As an aside it's taken me 2 full days of jumping through hoops to get S3D to do what I ask and even so, 3 colour prints are just about impossible. What's the point of having a priming tower that gets printed after the object rather than before? S3D has some nice features but it is the biggest PITA to use (in my humble opinion). Now to see if they'll honour their refund within 2 weeks policy. (Rant over).
I haven't yet found a way to switch S3D quickly and easily between generating gcode for my Cartesian and Delta printers. With slic3r it was really easy.
I just keep multiple profiles, a set for my Delta, and a set for my Cartesian.
Be sure to set the machine parameters in the individual profiles, and check the box to enable them upon use.
Thanks for reporting back Ian.
Unfortunately S3D does not solve the problem, and for the cost, I would expect more cutting edge features, and more attention to people's needs, so far slic3r wins, but least you are making progress going from 60% to 80% Since we are back to considering the hardware as the culprit, I would tear down the extruder and check the measurements, perhaps even count. I might do it tonight. -
But what I can't get my head around is that the extruders deliver exactly what is being asked of them - all 3 of them. i.e. I ask for 100mm to be extruded that's exactly what I get (well with a percent or so). That's by doing the "normal" 100mm test both with the hot end disconnected and with the hot end connected but heated. Also, if I mark the filament at 500mm, then print an object which should use 417mm of filament, then measure the filament again, it's within a percent or so of 417mm (but the finish is god awful - covered in blobs, lumps and stringy as hell with the nozzle dragging over the previous layers). Drop the extrusion down to 80% or so and all is sweetness and light.
Just doesn't make any sense…........
Are you 100% sure the nozzle diameter in your slicer is correct? I have a J-head that I thought was .5mm but it turns out it was much smaller than that and the first couple layers of the print I did with .5mm settings came out funny (the increased pressure caused the material to wiggle out like a snake causing some funky waviness)
@Nyl0cke:
Measured with drill bits (measured the drill bits with calipers). A 0.5mm drill goes in, a 0.6mm doesn't. I guess it could be 0.55 or thereabouts. Tried setting the nozzle diameter to 0.6mm in Slic3R - result just the same. (Thanks for the thought though).
Its a slicer setting somewhere
I have a feeling it's infill that's wrong and I have a feeling it's accumulative, as if each layer adds a bit more to the problem. Just observing with the naked eye, it looks as if the infill is always proud of the perimeter and gets a bit worse with each layer. It's very noticeable on the topmost layer. Strange though that Slic3R default settings do the same thing as S3D default settings. Also strange that I can use the same Slic3R settings that I used to use on my old RRP Mendel which worked well, but don't work on this machine. I have them set to default again at the moment but I'll try setting the same nozzle width and speed for perimeter and infill in Slid3R (but I'm sure I've done that before). Manyana - it's getting late.
Here's mine.
I'm running a Zortrax M200 converted to DuetWifi and PanelDue. Both are running latest firmware that isn't beta.
The direct extruder in these is extremely reliable, and the hotend is a common aftermarket called Z-temp than runs a Mk8 0.4mm nozzle, also very reliable.
Extruder steps/mm works reliably and consistently at 120 steps/mm @ 600mA. Never a click/jam/skip, always been bulletproof even before the conversion.
Pics below are generic ABS at 235 degC. I initially thought only minor changes would be necessary:
After speaking to Deckingham, I went harder at it:
For my money it seems that lower than 85% shows signs of under extrusion, in that I think I can see the previous layer.
I don't really care what the value is, I just want the best surface and would rather keep the actual steps/mm set at an accurate figure.
Please let me know your thoughts as to which surface looks best to you.
Sorry, should have said that's 0.2mm layer height with width set at manual/0.48mm. Filament was measured in 5 places and averaged to 1.714mm. I hope to use the extrusion setting across all other layer heights without going through all this process for each variation.
My twopence worth - difficult to compare with the lines being orientated in different directions (also looking at the real thing with the naked eye is better than photo's). If I had to make a choice, my personal favourite is 80% - just they way the infill joins to the perimeters. It does look to me that with higher extrusion multipliers the infill is raised above the perimeters (something that I'm seeing too) but we'd need some close ups looking sideways on, which might be difficult to achieve. I guess you are in the best position to make that judgement (sorry - that wasn't very helpful was it?).
It could be that whatever the reason, it might be different for other filaments or temperatures or speeds (not that I've observed any difference with speed and temperature with respect to this issue) or some other setting that we have not yet tried, so personally I think keeping the steps per mm and changing the extrusion multiplier is the best approach.
Are these all with 100% infil? I think what you are seeing is what was mentioned previously about filament packing.
For background reading I recommend Nophead's blog post about this here:
http://hydraraptor.blogspot.co.uk/2011/03/spot-on-flow-rate.htmlAlso interesting but for a different but not totally unrelated issue see this:
http://hydraraptor.blogspot.co.uk/2011/02/polyholes.htmlNot that when Chris was writing these the slicer used was skienforce which is now truely prehistoric. It did alow for significant customisation of how the Gcode was generated. Later slicers had abstracted this a bit more.
The potential issue with simply dropping to 80% flow is it affects a wide range of things. Such as hole sizes, layer adhesion etc.
These are all done the way I was instructed by David.
The multiplier was set to 1.0/100% in the slicer, then I used the extrusion slide bar in the DWC to drop 5% per square until I was happy with the surface, then use that setting in my slicer next time around.
I think 85% leaves plenty of meat there, but meets the level of the sides pretty much smoothly.
I'll read the links, but what do you think of the surfaces in the pictures? Which setting would you use?
