Setting up Cartesian Printer.
If you want to send Z all the way to the far end, at the end of the print, you can do it by using absolute(G90) rather than relative (G91) but it's really important that the Z is homed before you use this command. i.e. the machine must know where Z=0 is. So, it'll be safe to use in your end gcode as the machine will have been homed prior to starting the print.
So you could use:
G90 ; set absolute positioning
G1 Znnn F240This will move to Z axis to the absolute position of nnn from home, so set nnn to whatever you max Z is (less a few mm for safety and comfort).
If you haven't already done so, it's a good idea to set your axes maxima in you config.g. Like this
M208 Xnnn Ynnn Znnn S0; S0 defines maxima (S1 defines minima)If you do that, then once the machine has been homed, it'll wont allow you to send an axis past those limits. So if your Z max was 200mm and you tried to send it (using absolute positioning) to 250 mm, it would just stop at 200mm.
If you want to be really belt and braces, you could do what I do and fit additional end stop switches on the maxima of all the axes and wire them up in series and connect them to a spare e stop. Then use M581 in your config.g. One caveat to this is that if you use the DWC to send a movement, this is treated like a macro and the switch will be ignored. David has it on his list to change this.
HTHCheers Deckingham,
This particular machine is my first go with the Duet, and is a conversion of an existing printer, therefore no limit switch on the Z axis.
I do however have my axis' max's set, and yes it wont let you go past those presets.
S3D does have a homing in the start of the print.
When I do build my own printer I will definitely add an extra limit switch at the bottom of the Z axis.
I must say I am enjoying this printing system.
The printer runs much quieter (I've got a standard unconverted Zortrax running right beside it), and the temps hold absolutely rock solid.
I did update both the board and panel firmwares today and re run the temp tuning on the extruder and bed.
I'm messing around with raft printing in ABS at the moment, trying to get that velcro style rip off raft happening.
All in all the combination of the DuetWifi and S3D are working reasonably well in my inexperienced hands, much better than I expected.
That's good to hear. I'm thinking of switching from slic3r to S3D myself - just need to know if it can do 3 (or more) colour prints. It looks like it has some good features but might be a bit complicated for an old guy like me:)
If you can use slic3r then S3D will be a breeze and yes you can do multi colour prints.
It's not just multi colour that Ian needs tho He has to be able to handle 3 colour in a colour mixing hotend
Ian My offer still stands mate?
Doug
Oh where did I read that! The Diamond head needs firmware retraction as it pulls all filaments at the same time during retraction.
And that is a difficult trick to do and I think S3D doesn't support it. Dang, cannot find where I read it.
Bouncing between so many forums at the moment! (Wonder why?) I lose track of what I read where.The guys of Reprap.me should know for sure.
Lykle
It is supported on the Duet and S3D does support FW Retraction of a kind they use M101/102 and 103 codes which according to the RepRap wiki on GCodes has been deprecated in all but TeaCup firmware so we can't understand why S3D went that way at all
Fortunately you can post process all S3D Stuff very quickly within the SW Package by using the Scripting section to replace those M103 with G11 or whatever is required but it would be better if S3D Supported it on a FW Requirement basis it can't be that hard to do. mind I am not a software engineer so what do I know
Doug
Ah, great thanks Doug!
I'm an old bugger myself, and if I can use it I'm sure you can.
I think I beat you all hands down. 60. Old enough to be the winner here?
New version of S3D came out and they now specifically support multi extruder setups (3 and more)
Lykle
Unfortunately not Deckingman has that honour (I'll him admit to how much lol)
AS for multi extruders they have supported them for ages just not the easiest thing to get your head arround the main issue here is the Firmware Retraction that is essential for mixing hotends such as the Diamond?
Doug
Lykle
Doug
I was born in year of our present queen's coronation.
Ian.
P.S. If you bothered to check when that was, you should be ashamed of yourself for not having anything better to do.
I know when it was Ian but Lykle is a dutchman in Cyprus LOL. and for his benefit it was 1953.
Doug
Perhaps we should start a club for Over 60's 3D printing enthusiasts? I'd be eligible too!
Well you would have to wait a few months till I'm Eligible David (Mar 2017 for me).
Doug
OMG - old farts club!
Good idea. Will that mean concessions get a discount on Duet products?
No flatulence problem here son.
Steady on….I'm 47...which my sons assure me qualifies my entry into any old farts clubs.
Nah, your just a young slip of a lad.
