IDEX Support
New firmware 1.16 beta 5 with full IDEX support is now on GitHub.
Awesome. I have movement on U!
So far so good!
I'm begin to design a coreXY printer and this idea of IDEX is an huge improvement I thing and i would like to upgrade with this. Good luck, you are in the good way ! -
Cool idex on corexy? That's a first as far as I am aware!
I believe that dc42 came up with the idea of coreidexy on this forum, and harvested some ideas from the reprap forums. It is an idea that certainly has promise.
yes but the first implementation
I've just finished some preliminary work on Duet Web Control to support multiple axes. If you are using an IDEX configuration, you can try out my latest 1.13 beta 2 for Duet WiFi which is available here: https://www.dropbox.com/s/3eaafeubpfhsyge/DuetWebControl-1.13-b2.bin?dl=0. More features are coming soon!
Oh man!
Actually now i can't create Macros. I get an error saying could not update the file.
And i can't roll back. I uploaded the stable version and it asks if i want to install but it never does. How can i manually install the old version?
And i can't upload and print…...
To roll back, copy the version 1.12 DuetWiFiFirmware.bin file to /sys on the SD card (by moving the SD card to a PC temporarily if necessary), then run M997 S2.
Saw this awesomeness on Twitter, good Job. Following on from that conversation, I am not really up to speed on corexy however I am guessing you have you U axis Min and max at opposite ends from the X axis Min and max?
Oh Tony it's not corexy anymore. I converted to Cartesian in the end.
Ahh you never said! Whoops. In that case just chance your U axis to move in the same direction as the X axis and tell it that the U axis microswitch is a max not a Min.. the Wiki page example is a good starting point
Haha sorry!
Getting close. Need to sort purging and retractions a little.
Looking good! I am not bothering with a purge tower as the nozzles will be off the bed when not in use and I am working on how to handle purge and ooze. You have good alignment of the heads there, I will share my calibration file.for head alignment when I get a chance.
