2 Z motors, to endstops
Ok, config seems to be ok. So what exactly happens if you send G28 from DWC gcode console? If nothing moves, there should be some response message from duet why nothing moves. What that message says?
Just started a print...
yesterday, there was no message from DWC.
A click on "home all" did nothing, but i couldn´t move the motors by hand anymore.will test G28 asap
after powering up the printer, a single G28 without any parameter does nothing. the circle in the "send" button spins and spins and spins. when i click "emergency stop", a message "homing failed" appears.
then i homed only Z. works. after that, G28 works without any issue, same as the button "homeall"
That is odd. You are not supposed to be able home Z at all before X and Y are not homed. What firmware version are you using and what version of DWC?
Duet Web Control 2.0.0-RC3
Electronics: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
Duet WiFi Server Version: 1.22 -
@torro said in 2 Z motors, to endstops:
homeall
G91 ; relative positioning
G1 S1 X-300 Y-300 F5000 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-300
G1 S1 Y-300
G1 X10 Y10 F6000 ; go back a few mm
G1 S1 X-20 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y-20 ; then move slowly to Y axis endstop
M98 Phomez.gTry changing M98 Phomez.g to G28 Z
Ok. I will try.
I didn't test it yet, but i have an idea, i could put the home Z order on top in the first line. I Guess it works...
On my CoreXY also with 2 Z-Motors and 2 Endstops (1 for Z and 1 for U - Drive 2 and 3) i have to home Z also at first.
Only for example - without any garanty - see my homeall.g:
; ############## homeall.g -> called to home all axes ############## M98 Phomez.g ; X homing M98 Phomex.g ; Y homing M98 Phomey.g ; Z homing G90 ; ################# checking trigger height + Z null adjusting ################# G1 X144 Y150 F12000 G1 Z20 F1800 G1 Z15 F1200 G1 Z10 F600 T0 G30 ; Probe the bed at the current XY position, set the Z coordinate to the probe trigger height G4 P200 G1 Z50 F1800 ; END OF FILE
and my homez.g:
; ############## homez.g -> called to home the Z axis ############## G91 ; relative positioning M584 Z2 U3 P4 ; Split Z into 2 (Z+U) G1 S1 Z999 U999 F600 ; Move the bed down in the Z direction. S1 to stop if endstop is triggered G1 S2 Z-3 U-3 F600 ; Move the bed up 3mm in the -Z direction, ignore if axis are not homed G1 S1 Z9 U9 F200 ; Move slowly in the +Z direction again to stop exactly at the homing switch M400 ; Wait for current moves to finish G4 P100 G1 S2 Z0.00 U0.00 F200 ; Compensation the limit switch from z-axis drive 2 (!!can be adjusted here!!) G4 P100 M584 Z2:3 P3 ; Join U to Z again G4 P100 G92 Z282.00 ; set position of Z relativ to the bed (!!must be adjusted here!!) G90 ; Back to absolute mode G1 S2 Z270 F900 ; End of file
Good to know. Thanks!
@phaedrux said in 2 Z motors, to endstops:
homeall
G1 S1 X-300
G1 S1 Y-300
Same behaviour. I just put the m98 phomez. G in the first line of homeall.g
Now it works as expected
