2 Z motors, to endstops
Hi there,
i got it working. but not with drive 2&4. U didn´t move. tried a few things, no luck. So i changed it to 2&3 for Z and 4 for the extruder. worked immediately. i don´t know why, but it´s ok. maybe drive 4 has to be the V axis?
now, there is one small issue. when i power on the printer, i have to home Z first. when i try to home X or Y before, nothing happens???
what could that be?config.g and homing files:
homez
G91 ; relative positioningM584 Z2 U3 P4 ; split z control
G1 S1 Z-350 U-350 F2000
G1 Z5 U5 F400
G1 S1 Z-10 U-10
M584 Z2:3 P3 ; combine Z
G90
G92 Z0homey
G1 S1 Y-300 F5000 ; move quickly to Y axis endstop and stop there (first pass)
G1 Y5 F3600 ; go back a few mm
G1 S1 Y-206 F360 ; move slowly to Y axis endstop once more (second pass)
G90 ; absolute positioninghomex
G1 S1 X-300 F5000 ; move quickly to X axis endstop and stop there (first pass)
G1 X5 F360 ; go back a few mm
G1 S1 X-206 F360 ; move slowly to X axis endstop once more (second pass)
G90 ; absolute positioninghomeall
G1 S1 X-300 Y-300 F5000 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-300
G1 S1 Y-300
G1 X10 Y10 F6000 ; go back a few mm
G1 S1 X-20 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y-20 ; then move slowly to Y axis endstop
M98 Phomez.gconfig.g
M569 P2 S1 ; Drive 2 goes forwards Z @ Xmax
M569 P3 S1 ; Drive 3 goes forwards Z @ Xmin
M584 X0 Y1 Z2:3 U3 E4 P3 ; two Z motors connected to driver outputs Z and E0 Hide U
M350 X16 Y16 Z16 U16 E16 I1 ; Configure microstepping with interpolation
M92 X80.00 Y80.00 Z160 U160 E420.00 ; Set steps per mm
M566 X900.00 Y900.00 Z12.00 U12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min)
M203 X30000.00 Y30000.00 Z4000.00 U4000.00 E4000.00 ; Set maximum speeds (mm/min)
M201 X1500.00 Y1500.00 Z500.00 U500.00 E10000.00 ; Set accelerations (mm/s^2)
M906 X800.00 Y800.00 Z800.00 U800.00 E800.00 I40 ; Set motor currents (mA) and motor idle factor in per cent
M84 S3000 ; Set idle timeout; Axis Limits
M208 X0 Y-1 Z0 S1 ; Set axis minima
M208 X240 Y260 Z288 S0 ; Set axis maxima; Endstops
M574 X1 Y1 S0 ; Set active high endstops
M574 Z1 U1 S1 -
@torro said in 2 Z motors, to endstops:
This sounds like your Z motor is connected to X (drive 0) connector. If you home Z, what DWC shows? Homed X i guess.
No, all is running correct AFTER i homed Z.
nothing moves if Z is not homed. -
Please post your full config.g as well as config-override.g, (those on duet sd card, not somewhere in your computer, to eliminate possibilty that your backup ones in computer are not up to date)
no config-override in the system.
; generated by RepRapFirmware Configuration Tool v2 on Sat Nov 24 2018 10:45:17 GMT+0100 (Mitteleuropäische Normalzeit); General preferences
M80
M83 ; ...but relative extruder movesM667 S1 ; Select CoreXY mode
M550 P"MKC" ; Set machine name
M552 S1 ; Enable network
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Specials
M307 H2 A-1 C-1 D-1 ; disable the heater functionality
M569 P2 S1 ; Drive 2 goes forwards Z @ Xmin
M569 P4 S1 ; Drive 4 goes forwards Z @ Xmax
M584 X0 Y1 Z2:3 U3 E4 P3 ; two Z motors connected to driver outputs Z and E1 Hide U
M574 Z1 U1 S1; Z-Probe
;M558 P1 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed;
;G31 P500 X0 Y50 Z1.45
;M557 X20:220 Y70:240 S20 ; Define mesh grid; Heaters
M305 P0 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 0
M143 H0 S130 ; Set temperature limit for heater 0 to 120C
M305 P1 T100000 B4388 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
M307 H1 A438.2 C134.9 D3.9 B0; Fans
M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 T45:55 H100:101:102 ; Set fan 2 value,
M912 P0 S-3,5; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic power saving
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss; Custom settings are not configured
Ok, config seems to be ok. So what exactly happens if you send G28 from DWC gcode console? If nothing moves, there should be some response message from duet why nothing moves. What that message says?
Just started a print...
yesterday, there was no message from DWC.
A click on "home all" did nothing, but i couldn´t move the motors by hand anymore.will test G28 asap
after powering up the printer, a single G28 without any parameter does nothing. the circle in the "send" button spins and spins and spins. when i click "emergency stop", a message "homing failed" appears.
then i homed only Z. works. after that, G28 works without any issue, same as the button "homeall"
That is odd. You are not supposed to be able home Z at all before X and Y are not homed. What firmware version are you using and what version of DWC?
Duet Web Control 2.0.0-RC3
Electronics: Duet WiFi 1.02 or later
Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 2.02(RTOS) (2018-12-24b1)
Duet WiFi Server Version: 1.22 -
homeall
G1 S1 X-300
G1 S1 Y-300
M98 Phomez.gTry changing M98 Phomez.g to G28 Z
Ok. I will try.
I didn't test it yet, but i have an idea, i could put the home Z order on top in the first line. I Guess it works...
On my CoreXY also with 2 Z-Motors and 2 Endstops (1 for Z and 1 for U - Drive 2 and 3) i have to home Z also at first.
Only for example - without any garanty - see my homeall.g:
; ############## homeall.g -> called to home all axes ############## M98 Phomez.g ; X homing M98 Phomex.g ; Y homing M98 Phomey.g ; Z homing G90 ; ################# checking trigger height + Z null adjusting ################# G1 X144 Y150 F12000 G1 Z20 F1800 G1 Z15 F1200 G1 Z10 F600 T0 G30 ; Probe the bed at the current XY position, set the Z coordinate to the probe trigger height G4 P200 G1 Z50 F1800 ; END OF FILE
and my homez.g:
; ############## homez.g -> called to home the Z axis ############## G91 ; relative positioning M584 Z2 U3 P4 ; Split Z into 2 (Z+U) G1 S1 Z999 U999 F600 ; Move the bed down in the Z direction. S1 to stop if endstop is triggered G1 S2 Z-3 U-3 F600 ; Move the bed up 3mm in the -Z direction, ignore if axis are not homed G1 S1 Z9 U9 F200 ; Move slowly in the +Z direction again to stop exactly at the homing switch M400 ; Wait for current moves to finish G4 P100 G1 S2 Z0.00 U0.00 F200 ; Compensation the limit switch from z-axis drive 2 (!!can be adjusted here!!) G4 P100 M584 Z2:3 P3 ; Join U to Z again G4 P100 G92 Z282.00 ; set position of Z relativ to the bed (!!must be adjusted here!!) G90 ; Back to absolute mode G1 S2 Z270 F900 ; End of file
Good to know. Thanks!
@phaedrux said in 2 Z motors, to endstops:
homeall
G1 S1 X-300
G1 S1 Y-300
Same behaviour. I just put the m98 phomez. G in the first line of homeall.g
Now it works as expected
