Why am I having to run with an extrusion multiplier of 60%?
@ Peridot,
I know this is becoming a long thread so maybe you haven't read it all through but if you go back a bit, you'll see that I've done everything you suggest (apart from weighing object that is). On printing a 1cm cube, slic3r calculates that it will need 417.8mm of filament which is exactly right when you do the maths for 1.75 mm dia filament. On printing that object, my initial steps per mm where a little high and it actually used 437mm of filament. Adjusting the steps per mm from 424 to 405 has got it very close. That is to say, when I print the object it uses very close to 417.8 mm of filament. That's with retract on layer change enabled so it's a good "real world" test which gives me confidence that the extruders are doing exactly what hey are supposed to do. The freaky thing is that the resultant cube has all the attributes of an object where the extrusion setting was too high (bulging corners, poor finish, lumps and blobs and dimensionally slightly too large). If I then print the same cube with an extrusion factor of 0.8 then it uses 80% less filament (around 330 mm) but the resultant object looks perfect, (although it is dimensionally a little under sized).
Ref difference in nozzle size? It beats me. When sliced, the calculated filament usage and object volume are the same, yet the print quality is totally different. 0.5 gives the effect of severe over extrusion (as detailed above), whilst 0.6 gives the effect of under extrusion - gaps between the lines, poor adhesion etc. My only thought is that the spacing between lines must be different. e.g for an object that is say 30mm across, if the slicer thinks the extruded filament is 0.6 mm wide, it will take 50 lines of filament to span that width, but if the slicer thinks the filament width is 0.5 mm, it will take 60 lines. Of course, the 50 lines should have more filament per line so it ought to cancel out.
I'm planning on doing a series of prints with the same object sliced using nozzle widths between 0.5 and 0.6 in 0.01 increments just to see.
After that, I think I need to find a nice sun bed, somewhere hot and sunny, next to a pool, in order to restore my sanity.
Sorry about that. I see you have been pretty darn thorough - I just don't like mysteries either.
It's starting to sound like a slicer problem of some kind - if the extruder is putting out just what it was asked to, then the slicer must be asking for too much plastic, surely?
The nozzle diameter does affect what thicknesses of filament and layer heights are a good idea. Specifically, you can't easily lay down tracks much thinner than the nozzle size. So for slicers that automatically determine the width of infill, a bigger nozzle will lay down thicker lines (and fewer of them). So there will be differences in what the print looks like. Some of these differences will be non-obvious: the cross-section of a piece of extruded filament is a complicated rounded-edged shape that depends on the layer height, the nozzle width, the intended width, whether there are any other lines nearby, and even whether the path is curving. So the prints should look different, including whether there are air gaps inside them, but the total amount of plastic should not change.
The sun bed is starting to sound like a good idea.
Nothing wrong with that logic. However, when I slice a 1cm x 1cm x 1cm cube, with 100% infill and no skirt or brim, then check the gcode file, slic3r reports the volume to be 1cm^3 and that it will take 417.8 mm of filament to produce the object. If you do the maths, using 1.75 mm dia filament you get (1.75/2)^2xPi x 417.8 = 1000mm^3 (or 1cm^3). So on that basis, the slicer is asking for exactly the right amount of filament (and I now know that the printer will deliver exactly what it is asked to deliver).
When I print the object, it has the appearance of being printed with too high an extrusion rate and if I print it with 80% of the correct amount of filament, it has the appearance of being printed with the correct amount of filament. Note that I am now using the expression "appearance of" rather than stating that it is over extruded. I think there is a distinction somewhere between the two - but I'm not sure yet what that distinction is.
Not that this is driving me crazy but I have to go - there is a little man wearing a white lab coat knocking on the door….....
Have you tried a different filament?
I wonder if your printer is not printing in the correct x/y scale? Have you verified this? If your 10x10 cube with the correct volume of plastic is trying to take up 9.5x9.5 area, it would be squishy. Maybe incorrect Z scaling, too?
@bot:
Hi bot
As per one of the above answers, cubes are a little undersized when extruding at 80% (about 0.2 to 0.3 mm) and a little over sized when extruding at 100% (again, about 0.2 to 0.3 mm). That's regardless of the size of the object so on a 10mm cube its +/- 2 to 3 % but on a 100mm it's +/- 0.2 to 0.3% depending on the extrusion amount I use. Given that it can be under or over, I'm reasonably certain that the steps/mm in X Y and Z are correct.
Ian -
I only have PLA - that's all I've ever used to date. I get the same result with "solid" Black and White and translucent Red, Yellow, and Clear, so 5 different reels but all PLA. They were from 3 different sources and bought at different dates about 4 months between the earliest and newest. I keep the filament in evacuated plastic bags with silica gel in the bag - the colour changing stuff that tells me when it's becoming saturated (and it's not).
Latest (and probably final) update. Firstly here is a link to a picture of the issue.
https://drive.google.com/file/d/0B_MwtHtQR_ZvbkJoN0l1Y3FUYTQ/view?usp=sharing
It's exactly the same part, the only difference is that the one in the foreground was printed using an extrusion factor of 1.00 and the (better) one in the background was printed using an extrusion factor of 0.80. When the printer puts down the first layer, with extrusion factor of 1.00, the edge of the extruded filament is "rippled" - as if there is too much filament with nowhere to go, but with an extrusion factor of 0.80 it's a nice smooth "tube" of filament. When the vertical sides are being printed, these large blobs appear using 1.00 and I get stringing as if there is too little or no retraction, but there is no sign of any of this using a 0.80 (80%) extrusion factor. It's almost as if there is a build up of pressure at the nozzle tip caused by too much filament trying to be forced out through too small a gap and then suddenly is just "explodes" and releases the pressure but causes the blob. It looks like it can happen at any point, either on the perimeters or in the solid infill.
My thoughts at this moment in time are that it has to be over extrusion and that there is nothing else weird happening that is being masked buy under extruding. There also seems to be quite a bit of discussion on the "interweb" with many users of slic3r version 1.2.9 having the same problem. Some have said that rolling back to an earlier version fixes it. I know that if I slice a 1cm^3 in slic3r it generates exactly to correct amount of filament to fill that space. Maybe that's the problem. As someone has said, because of the way the filament is laid down, it's not "cube" shape so there will be gaps between individual threads at some points. So, it should take less filament to fill a given space to account for these gaps (but 20% or more seems an awful lot).
I've looked at other slicers but don't want to pay money in case that's not the problem. Other free ones don't have the features I need (like support for firmware retraction and multi colour parts for example). So, much as it pains me, in the interest of saving what little sanity I have remaining, I'm going to give up and just run with slic3r and a low extrusion factor, or maybe try an earlier version.
(Unless of course, someone comes up with a better idea…........).
Ian -
You tried this? https://www.raise3d.com/pages/ideamaker
Thanks for the thought - had a quick look- seems to be specific to their machines - apart from anything else, it only support 2 extruders and I have 3.
Hi Ian
Try Cura to see if its the slicer, even if it does not suit all your other needs.
Hi Tony,
I'm convinced it's slicer (slic3r) related. Got Cura but it doesn't do firmware retraction (at least I can't find it). So even if it worked in other respects, I'd be printing with effectively no retraction and the prints would still be awful. At least with slic3r and setting extrusion factor of 80% in the filament section, I can get decent quality prints. I've enquired of S3D as to whether they have plans to support firmware retraction -waiting for a reply. AFAIK, slic3r is the only one that does multi part (multi colour) objects and firmware retraction.
Ahh fair enough, I don't use firmware retraction, never found the need at least in a single extruder setup.
I have it in mind to support auto firmware retraction as Marlin does, i.e. identify retraction/un-retraction gcodes and use the firmware retraction parameters for them. But there is the possibility of mis-interpreting moves. So firmware retraction support in S3D would be better.
Just looking through the online documentation, it doesn't look like S3D can support 3 extruders either. Dual extruders but not 3 (unless someone can advise me otherwise).
Slic3r actually gives you the choice of 4 extruders (tools) to choose from if you define the printer as having 3 extruders. I guess the authors were aware that with a mixing hot end you can have any number of combinations. Shame it's giving me this problem because otherwise, it does everything I need (but at least I've found a workaround). -
Looking at my S3D Install it appears that it CAN support upto 6 Tools (Don't ask how you configure it) but you can select from tool 0 to tool 5.
Doug
About the 2 cubes, with the weird 1st layer print patterns.
It looks to me as if the bed isn't level. On the brim it looks as if the layer thickness in the foreground is better than in the background. The foreground looks squished while in the back it looks put down loosely on top.
That could account for the strange patterns in the first layer.Will not help you with the extrusion issues, tho.
Lykle
I'm not sure I understand - why can't you use software retraction? More generally, why should anyone prefer firmware retraction over software retraction?
Regardless, it might be interesting to print some experiments with Cura even if they have no retraction; maybe even some slic3r experiments without retraction to compare. The point is, is slic3r doing something wonky? (The bug in slic3r 1.2.9 is supposed to occur only when filling tiny gaps, which get overfilled.)
It can't hurt to check dimensional calibration on your printer. By this I mean the dimensions used by the motion system; extrusion problems will mess with any dimension by a fraction of an extrusion width, so you want to print the biggest part you can accurately measure. I also found it helpful to print both "outside" and "inside" dimensions to measure, so that they would be affected by extrusion wonkiness in opposite ways. I designed a part that should show what I mean: http://www.thingiverse.com/thing:1688991 (last object) That's for a (small) delta; on a Cartesian you'd make it rectangular. And to decrease the volume by 80% you'd only need to scale the axes by 93% each, so it wouldn't take all that much dimensional inaccuracy.
I should say, though, that I can print cubes sliced with slic3r 1.2.9 and get perfectly-reasonable-looking output with steps/mm calibrated to reality, filament diameter set to the measured 1.72 mm, and an extrusion multiplier of 1.0. So if there's some weird slicer bug, I don't see why it hits you alone.
Lykle
Hi Lykle.
Agree with that. Sorry, I mean to report back but got overtaken by other events. Bed had moved by 0.05mm. Not apparent when extruding normally but when the extruder was seriously under extruding that 0.05 makes a noticeable difference to the first layer.
@ peridot.
Firmware retraction is needed for mixing hot ends such as the diamond which I use. More accurately, it is necessary to retract all filaments simultaneously when they share the same nozzle. DC42s implementation of G10/G11 allows that to happen. If one only retracts one of the filaments, then all that happens is that filament is drawn from one of the other inputs, rather than from the nozzle tip.
Edit. As for your other suggestions (thanks for taking the time though), I'm fully aware that it could be, and most probably is, something specific to my machine. Obviously, when I first noticed the issue, that's the route I was taking (for several weeks). I've checked the dimensional accuracy numerous times as well as orthogonal accuracy and just about everything else I can think of. Speed, acceleration, j**k, temperature, (fast, slow, hot, cooler) - none of these make any significant difference. Fast speed is maybe slightly better than slow but not much in it. It was only after doing weeks of these sort of checks that I stumbled upon the fact that I could remedy the issue by lowering the extrusion amount.
I don't know if you saw this in one of my earlier posts https://drive.google.com/file/d/0B_MwtHtQR_ZvbkJoN0l1Y3FUYTQ/view?usp=sharing. The only difference between the two prints is that the one with the blobs and strings and lines in the layers was printed with an extrusion factor of 1.00 and the other at 0.80. It beats me….......
It's also handy because you can make adjustments to your retraction on the fly rather than having to make changes in the slicer and start over. This is very helpful when getting your retraction settings dialed in for a particular filament or when trying new extruders and hot ends.
@ peridot.
